Grille insert compatibility
Discussion in '2.5 Gen Tundras (2014-2021)' started by Highrockies, Apr 9, 2025.
  1. Apr 9, 2025 at 8:41 AM
    Highrockies
    Highrockies [OP] New Member
    Hey there Tundra community. I’ve got a 2020 SR5 and want to replace the grille with a color match surround. I can get a 2017 grille and want to swap the insert with what’s on my 2020.
    Is the 2017 surround compatible with the 2020 insert so all of the clips and hardware fit?
  2. Apr 9, 2025 at 8:41 AM
    RobertD
    Robert
    DFW, Texas
  3. Apr 9, 2025 at 8:57 AM
    Highrockies
    Great to know. Thx.
  4. Apr 9, 2025 at 9:05 AM
    Yes it will but be careful as those clips are known to break easily.
  5. Apr 9, 2025 at 10:24 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    do they ever.
    Its been nearly a decade since I added my pro grille and still distinctly remember how tense and unenjoyable it was trying to be as gentle as possible to remove the OEM grill and still have clips left to snap in the new one.
    Highrockies[OP] likes this.
  6. Apr 9, 2025 at 11:17 AM
    RobertD
    Robert
    DFW, Texas
    Use some channel locks pliers, one jaw on the end of the clip, other jaw on the piece you are removing. A little (seriously, just some pressure) and you can pop the clips with ease. I've removed 3 inserts now and using the channel locks, I've broken 1 clip. It now takes a few minutes.
    But without the channel locks, it is definitely stressful and time consuming, and you have a really high chance of breaking a clip no matter how careful you are being.
    Highrockies[OP] and PlatinumPro like this.
  7. Apr 9, 2025 at 1:10 PM
    Highrockies
    That’s great advice. Thanks!
  8. Apr 9, 2025 at 1:14 PM
    PlatinumPro
    the things i didn't do lol. Solid little tip!
    RobertD[QUOTED] likes this.
  9. Apr 10, 2025 at 1:50 PM
    Highrockies
    Can you post a photo or video of your channel lock method?
  10. Apr 10, 2025 at 2:47 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Won't there be an issue with mounting the cruise control radar? Or am I not thinking straight?
  11. Apr 10, 2025 at 4:14 PM
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    He's keeping the original insert so the sensor shouldn't be an issue. He's only swapping the surrounds.
  12. Apr 10, 2025 at 4:15 PM
    JDR76
    JDR76 New Member
    WA
    Ah, thank you. I read it backwards as replacing the grille but keeping the surrounds. Knew I was missing something...
    20manny1996[QUOTED] likes this.
