Grill Swap Complete / 2017 SR5 Grill to 2018 Honeycomb Grill
Discussion in '2.5 Gen Tundras (2014-2021)' started by drhaynes, Jun 14, 2018.
  1. Jun 14, 2018 at 4:12 PM
    drhaynes
    drhaynes [OP] I meet the nicest people in a Tundra
    Central California
    2020 Tundra SR5 Crew Max 4WD White
    Received 2018 Honeycomb grill, surround and bulge today. Fifteen minutes later, swap was complete. Couldn't have been easier, but there was one minor issue (gap between hood bulge and lower surround is larger than original grill.
    Before:
    After:
    Excessive gap between bulge and lower surround:
    Anyone else run into this problem? Initially, I changed the grills without changing the bulges as both looked to be the same. Upon noticing the increase in the gap, I changed the bulge also. No improvement. I considered putting the 2018 insert in the 2017 surround, but not sure that will change anything either. Thought maybe someone else might have been down this road already.
    yoshi82, SomeGuy4 and My14Tundrs like this.
  2. Jun 14, 2018 at 4:21 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I did the swap a couple weeks ago. What emblem did you use?
    orgillmx, yoshi82 and My14Tundrs like this.
  3. Jun 14, 2018 at 6:06 PM
    drhaynes
    Central California
    The seller left the stock emblem on the grill. Looks like you have the same gap problem I have.
  4. Jun 15, 2018 at 10:00 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    there are 2 rubber bumpers that the hood sorta rests on when you close your hood you can easily adjust them by hand just twist them either up or down and it should adjust the gap I had to do that when I changed my grille @drhaynes
    BravoDeltaRomeo and Pudge like this.
  5. Jun 15, 2018 at 10:11 AM
    drhaynes
    Central California
    Thanks. I looked at those and was under the impression they were bottomed out. I’ll take a closer look at them. Thanks again.
  6. Jun 18, 2018 at 5:42 PM
    Tess
    Tess New Member
    2018 SR5
    3.5 Lift, Method Racing Wheels, few odds and ends
    Did that to mine.
    AggiePhil, yoshi82, Durania and 4 others like this.
  7. Jun 23, 2018 at 7:11 PM
    kih72
    kih72 New Member
    Did you purchase the whole grill assembly, or just the honeycomb insert? Or, is that not even an option?
  8. Jun 23, 2018 at 7:19 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Not an option unless you buy someone's used insert
  9. Jun 23, 2018 at 7:20 PM
    Pudge
    CT
    I'm pretty sure that stock emblem is worth some good money. You can replace it with a landcruiser one that doesn't have sensors for cheap, if you can find a buyer looking for the expensive one
    Jlo23 likes this.
  10. Jun 23, 2018 at 7:23 PM
    Pudge
    CT
    You can do this but run the risk of breaking some tabs and mounting points. It's a pain in the ass. May not be worth the effort to close that gap. But its possible
  11. Jun 23, 2018 at 10:04 PM
    kih72
    kih72 New Member
    Thanks for the reply. Do you happen to have the part number for the grill? I keep coming up with the 2014-17 part number. Also, do you know if the emblem on the 2014 will fit in the 2018 grill?
  12. Jun 23, 2018 at 10:06 PM
    Pudge
    CT
    14 emblem will not fit an 18 grill. @Roman knows what emblem fits I think it's from a recent generation landcruiser
    Roman likes this.
  13. Jun 23, 2018 at 10:15 PM
    MGMTUNDEE
    MGMTUNDEE New Member
    Quacky
    Tampa
    I prefer the honeycomb by a long run, also color matched my surround and bulge
    AggiePhil, GODZILLA, Micnola and 3 others like this.
  14. Jun 23, 2018 at 10:22 PM
    kih72
    kih72 New Member
    Thanks for the help!
  15. Jun 23, 2018 at 10:34 PM
    drhaynes
    Central California
    I bought the entire grill including surround and bulge. It is however possible to buy the insert only. Just a few screws and a bunch of tabs to unhook without breaking them. Most used grills will or should have emblem plate with grill as it will not fit on the grill it replaced. Literally took 15 minutes to change grill. Just have to keep watching for one to come available.
    jrey28 likes this.
  16. Jun 25, 2018 at 7:16 AM
    Tess
    Tess New Member
    2018 SR5
    Just the insert and had the surround painted to match the body color. I like the look of this grill on my Tundra.
    Tess
  17. Jun 25, 2018 at 8:24 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  18. Mar 17, 2019 at 2:12 PM
    Micnola
    Micnola New Member
    2017 Toyota Tundra
    I have a 2017 SR5, can you say where you got the grill, surround & bulge?
  19. Feb 26, 2020 at 9:28 AM
    Praz
    Praz New Member
    Grille
    I just bought a new grille but the hole to insert the old logo is different (2017 to 2018)
    Any recommendations?
  20. Feb 26, 2020 at 9:35 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I am finishing painting my 2015 sr5 chrome bulge 202 black and I'll be putting my 2020 pro grill on. I cant seem to see this gap you guys are talking about. I noticed on the pro grill that the shape near the top where the screw points are is a bit different than my old sr5 one.
  21. Apr 1, 2020 at 9:44 AM
    Maresscuba#103
    Maresscuba#103 New Member
    2017 Tundra SR5
    Hello sorry but after reading the posts I'm still just as confused. Can anyone tell me if a 2017 Tundra SR5 insert only can be swapped with an 18 honey comb insert only?
    easleycrawler likes this.
  22. Apr 1, 2020 at 10:35 AM
    easleycrawler
    Travis
    Yes I have done it. But you will need a emblem from a land cruiser, it is a direct fit, no modifications and another little piece.
    @Roman can hook you up with everything you need. Plus they have free shipping right now. That will save you a good bit.
    Roman likes this.
  23. Apr 1, 2020 at 10:49 AM
    Broncoman
    Broncoman New Member
    I have a 2017 (1794 edition) I'm also interested in finding our exactly what one you bought and where you got it?
  24. Apr 1, 2020 at 11:04 AM
    easleycrawler
    Travis
  25. Apr 1, 2020 at 1:10 PM
    Broncoman
    Thank you!
  26. Aug 22, 2020 at 4:52 PM
    chucky1815
    chucky1815 New Member
    Chucky
    2016 Toyota Tundra SR5
    anyone know if the Honeycomb insert fit in 2016 surround?
  27. Aug 22, 2020 at 4:59 PM
    Yes, I'm pretty sure 2014 and up will all fit.
    @Roman he will definitely know but probably won't reply until Monday.
    chucky1815[QUOTED] and Roman like this.
  28. Aug 22, 2020 at 5:00 PM
    Welcome from NY, by the way.
    chucky1815[QUOTED] likes this.
  29. Aug 24, 2020 at 12:01 PM
    Roman
    Roman
    Franklin, TN
    They will fit.
  30. Aug 26, 2020 at 5:49 PM
    chucky1815
    Chucky
