Grill mounting brackets ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dryflyhunt, Feb 5, 2018.
  1. Feb 5, 2018 at 7:57 AM
    Dryflyhunt
    Dryflyhunt [OP] New Member
    2016 Black Tundra Crewmax Limited TRD
    Tint, tonneau, chrome to black
    Please forgive me if I sound ignorant, but I am looking to replace my current 2016 Limited grill with an aftermarket grill. I have the grill for sale on FB and a guy just asked if the mounting brackets come with it? Would I need these brackets for the new grill or is it totally different for each grill? I haven’t poked around under the hood enough to answer this question so I’m turning to you all fine people...please advise:)
  2. Feb 5, 2018 at 8:20 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    The grille is held on with plastic tabs and the hardware along the top. There aren’t really any brackets. You reuse the hardware on the top with most grilles and many aftermarket grilles use the current surround after you cut out the insert. Be careful not to break the tabs the first time you remove it, it is pretty simple once you see how it goes together.
    DE46AE76-525A-450C-B5BC-D2EBDF522E72.jpg B6F16B62-7DE8-4431-8653-7409358959B2.jpg
    Dryflyhunt[OP] likes this.
  3. Feb 5, 2018 at 8:21 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    There are no mounting brackets per se. It's all integral.
