Green led drl question
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyoBro, Nov 26, 2016.
  1. Nov 26, 2016 at 12:53 PM
    ToyoBro
    ToyoBro [OP] New Member
    2015 white TSS CREW CAB 5.7
    Got some green leds for the daytime running lights, blows out the hazard fuse, and doesn't work do I need a special fuse to put in the place that says led drl?
  2. Nov 26, 2016 at 1:05 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yes the LEDs for the blinkers require a resistor to funcition properly.
  3. Nov 26, 2016 at 1:08 PM
    csuviper
    Broomfield, CO
  4. Nov 29, 2016 at 2:25 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    The LEDs bulbs for the Daytime Run lights/Signal lights need (I believe 3157K) not the 3157. The leds work differently then standard filament bulbs. The resistors are only needed to stop the hyper flash due to the very low power draw. I blew a few fuses before I figured it out. I would just buy the resistors (2 per side) and hook them up yourself. The ones fully assembled, at least when I bought them from Amazon, were wired backwards and blew some more fuses. I can post a pick of my setup later.
