Greece (Buying a 2007 Tudra)
Discussion in 'New Member Introductions' started by Greece1980, Jun 28, 2020.
  1. Jun 28, 2020 at 1:19 PM
    Greece1980
    Greece1980 [OP] New Member
    Hello from Greece, my name is Nikolas, looking forward for a buy of a 2007 5.7L Tudra Limited with 170.000 miles on from Bulgaria. What should i check on the truck before buying it, i drived the truck and its going fine with no noisy sounds or anything else while driving, transmision works fine, rust under the truck is not so much, about engine what should i check? There is something I need to check specifically other than the standard ones? This is the VIN number of the truck: 5TBDV58197S470234. Last record service in US form Toyota owners website was to Koons Westminster Toyota dealer with 51.400 miles at 12/30/10. The truck is for professional use exclusively and towing a 4000kg trailer. Toyota dealers in Bulgaria or Greece when i ask about Tudra they look me like im from other planet... thanks in advance!
  2. Jun 28, 2020 at 1:45 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal
    Greece1980[OP] likes this.
  3. Jun 28, 2020 at 2:41 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Welcome from Utah, USA. The things I would consider either exchanging or checking are the wear parts, such as water pump, shocks, brakes, etc. If you take it to a Toyota dealership tell them it's similar to a Land Cruiser 200 series. The engine and transmission anyway, that should help. If you buy it, consider a full service, differential fluid change, transfer case fluid change (if 4WD), and transmission fluid change, and Engine oil of course. These items are mostly because it's an '07 and if it's like any of the US Tundra's, they haven't been changed in their lifetimes. I don't think the '07's had the AIP issue as much as later years, and the cam tower seal leak also showed up later too, so other than that it should be a solid truck.
  4. Jun 28, 2020 at 2:45 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
  5. Jun 29, 2020 at 6:18 AM
  6. Jun 29, 2020 at 7:26 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  7. Jun 29, 2020 at 7:45 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Welcome from Florida!
  8. Jun 30, 2020 at 2:51 PM
    Welcome from NY.
