Grade of fuel
Discussion in 'General Tundra Discussion' started by blazin461, Nov 2, 2015.
  1. Nov 2, 2015 at 5:59 PM
    blazin461
    blazin461 [OP] New Member
    Rob
    2016 SR5 Magnetic gray metallic
    Stock
    Brand new guy here as of today. The build date on my new 2016 SR5 5.7 was to be yesterday. Am expecting delivery by November 15th. I am getting out of my 04 Ford F250 6.0L diesel. Have not run a gas truck since 2002. My question is what octane or grade of gas do I run in this new 2016 5.7L? Also, are fuel additives or fuel system cleaners necessary in this engine?
    4x4_Angel likes this.
  2. Nov 2, 2015 at 6:25 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Location makes a difference. Where do you live?
    Here in co we can get away with lower octane because of the higher altitude. I run only mid grade which is 87 here.
    Oh and welcome!
  3. Nov 2, 2015 at 6:29 PM
    Welcome!
    I run mid grade (Shell) you should be fine with unleaded....unless you're supercharged :burnrubber:
  4. Nov 2, 2015 at 6:32 PM
    andrew
    andrew where's the beer?
    andrew
    2012 rockwarrior
    stock
    I used to run 89 the first 20k miles, but then started using 87. Never had any issues and to be honest couldn't really tell a difference in gas mileage or anything. Some people claim they can, most can't. But as sean mentioned, unless you're supercharged or anything you should be fine on the 87
  5. Nov 2, 2015 at 6:36 PM
    Welcome from Aurora, CO. You should use 87. Higher octane or lower octane will not make much of a difference. Your engine is programed to be the most efficient at 87 octane unless you use a Bully Dog tuner to change the factory programming.
  6. Nov 2, 2015 at 6:43 PM
    csuviper
    Broomfield, CO
    Lower altitude filling stations have 87/89/93.
    Higher altitude filling stations have 85/87/91.
  7. Nov 2, 2015 at 6:44 PM
    csuviper
    Broomfield, CO
    I would go 89 at lower altitude.
    87 at higher.
  8. Nov 2, 2015 at 6:47 PM
    Post 3,999.
    Ocd going nuts...make that a 4K post!
  9. Nov 2, 2015 at 6:51 PM
    If I'm not mistaken, if you buy your tundra in Cali for example, it's programmed for that state's fuel regs/requirements. 2 or 3 octane difference is no difference other on your pocket book. Example : LA beach, surfing = 0ft altitude. Within one hour you can be skiing at Mt Wilson at 5700 ft. 87 or 89??
  10. Nov 2, 2015 at 7:10 PM
    blazin461
    Rob
    Stock
    I am in Michigan. I did read something about that these engines are designed to run on 87 octane grade.
  11. Nov 2, 2015 at 7:16 PM
    The thing is...............where is the split from low altitude to high altitude? (Gee I started at 0 ft and now I'm at 2800 ft, should I switch to 87 octane now or wait until I get to 5280 ft? Check with your local Toyota dealer on what octane they recommend for your driving conditions in your state/area. (I bet it will still be 87).
  12. Nov 2, 2015 at 9:26 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Spec calls for 87. Just always buy top tier and you should have no problems. Contrary to what the next guy is about to tell you, buying a higher octane grade than your vehicle is tuned for is a complete waste of money.
    tomsinamerica, jlee and Black Wolf like this.
  13. Nov 3, 2015 at 5:45 AM
    Agreed. I have a friend who lives in Big Bear, CA and is now retired. Before he retired he drove from Big Bear to Riverside to work (ouch). High altitude, 6700ft to 800ft. Lots of time spent on freeways but then again lots of time up in the mountains. 87 is available at both climes for a reason.
  14. Nov 3, 2015 at 6:48 AM
    blazin461
    Rob
    Stock
    What would you consider top tier?
  15. Nov 3, 2015 at 9:01 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Black Wolf likes this.
  16. Nov 3, 2015 at 4:40 PM
  17. Nov 4, 2015 at 4:31 AM
    Airbagged
    Airbagged New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    I only run REC fuel with no ethonal, I get on average 1-2 miles more per gallon running the rec fuel over running regular fuel with ethonal in it. The octane of the REC fuel I run is typically 90. One of the first mods to my truck was the transfer flow 46 gallon tank so it makes it easier for me to find gas stations that sell REC fuel, I also use a fuel finder app on my phone that tells me stations that sell REC fuel. Running this fuel I don't have to worry about all the issues with ethonal fuels, which in my humble opinion suck!!!
    Ethonal fuels cause all sorts of issues from gumming up to water build up in the fuel tank. Ethonal fuel also has less potential energy per molecule of fuel, so any savings in cost is negated in the long run.
  18. Nov 4, 2015 at 5:23 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I've been using 87 since when I got my truck. I've tried higher octane fuel, but I saw absolutely no difference in terms of power or mpg. So I went back to 87. The truck has been running flawless so far.
  19. Nov 4, 2015 at 5:33 AM
    Airbagged
    I think a lot of people want to add gas to a tank, and see some sort of instant reaction, but in reality it's more about long term effects on the engines internal components. Less carbon buildup, less pre detonation, there are a lot of added benefits to running a cleaner higher octane fuel on a regular basis. Just because you don't feel a difference after fueling up, doesn't mean your engine is not benefitting from running a better fuel. The added cost to run better fuel to me is worth it!
    Metro14536 likes this.
  20. Nov 4, 2015 at 5:43 AM
    chphilo
    Western PA
    You may be right. I didn't use 93 for an extended period. But there have been others who used it for a longer period and they come away with the same conclusion, no difference. Toyota's own recommendation is 87 (higher for supercharged Tundra). I tend to stick with Toyota's recommendation unless I see a clear evidence otherwise. There have been some guys who claimed that 0w-20 is not good for Tundra, They recommend 5w-30, 5w-40, etc. Unless I see a clear evidence supporting their claim, I usually stick with oem recommendation (I use 0w-20, Mobil1). I guess I am a conservative in that respect.
  21. Nov 4, 2015 at 5:51 AM
    Airbagged
    I've worked on engines for quite a while now, and taken many apart, I've seen the internal difference of running different fuels, which is how I come to my personal conclusion. I'm also just old enough to remember carborators and have rebuilt a crap load of them! Running Fuels containing ethonal in anything with a carb is a big mistake!! Yes I know we don't run carbs in our modern fuel injected engines, but that doesn't mean we don't get similar deposits in our fuel systems.
  22. Nov 4, 2015 at 6:04 AM
    Airbagged
    Fuels that contain Ethonal will develop water in the tank, which is a direct result of ethonal absorbing water once the ethonal is saturated it separates and the heavier water settles to the bottom of your tank, which is directly where your fuel pick up takes in the fuel. There is also a bacteria which develops do to the presence of the ethonal and water combination which causes a sludge like buildup. There are enzymes you can add to the fuel to try and prevent this, but then your just adding to the overall cost of your fuel fill up.
  23. Nov 12, 2017 at 6:30 AM
    Lxa772
    Lxa772 New Member
    Jake
    Tundra limited 2017
    hey guys new to the team just purchased a 2017!! Drives perfect! Quick question any suggestions on the fuel to use? I went from luxury car to now a awesome truck! Any suggestion on the fuel ? Does it matter with 85 octane or 91?
  24. Nov 12, 2017 at 6:33 AM
    I always run 87 octane in mine. Congratulations on the truck and Welcome from Ohio!!:worthless:
  25. Nov 12, 2017 at 6:36 AM
    Lxa772
    Lxa772 New Member
    Jake
    Tundra limited 2017
    Thank you very much for the quick response and the welcome! Growing up my pops has a Toyota usto go off roading! Finally pulled trigger and joined the club! I really am happy to have it! Thanks 87 octane sounds good!
  26. Nov 12, 2017 at 6:52 AM
    No, unless you’re running an aftermarket tune unleaded is fine. I do run mid-grade just because. :)
    Welcome from CO!
    Marty McFly likes this.
  27. Nov 12, 2017 at 7:44 AM
    Marty McFly
    Morty McBoonJug
    Welcome from SoCal sir :hattip:
    I use regular on most days. CA gas is ridiculously expensive plus tundras burn through gas like it was going out of style :annoyed:
    Just a friendly reminder: :worthless:
    Y0TA PR0 likes this.
  28. Nov 12, 2017 at 7:52 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO. 85 is good for me. No issues with truck running on that.
  29. Nov 12, 2017 at 7:59 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Jake. Whatever the cheapest octane here in Ca. is.
  30. Nov 12, 2017 at 8:06 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Jake, welcome to the family from Las Vegas. I have a brother named Jake as well. Good name!
    Bob likes this.
