Got my headlights restored
Discussion in '2nd Gen Tundras (2007-2013)' started by Tridom, Feb 6, 2024.
  1. Feb 6, 2024 at 4:56 PM
    Tridom
    Tridom [OP] New Member
    Dominick
    Hampton Roads, VA
    2012 Tundra SR5 4.6L V8
    So.. my headlights over the years got really foggy to the point I actually started having difficulty seeing at night.
    Looked into buying new ones and had a heart attack at the prices.
    Looked into doing it myself and didn't want to go through all of that sanding with different grits of sandpaper over and over.
    So I went around the corner to this auto restoration place. He used 2000 grit paper on them right from jump. Then polished them and coated them. 1/2 hour.
    Best 80 bucks I spent! They look like they came right out of the factory.
    I asked how many months it would last until I had to come see him again. He said about 36 to 48.
    I'm happy.
    WILLINH and GODZILLA like this.
  2. Feb 6, 2024 at 4:58 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. Feb 6, 2024 at 5:21 PM
    Tridom
    Dominick
    Hampton Roads, VA
    Well, don't have any before. Didn't think to take one. But I'll take one tomorrow of the after.
    One thing that got me was everything I read for DIY said to start with a really coarse grit paper and work out through like 4 different grits down to 1200. This guy went directly with 2000 grit on a sander and it worked like a charm. He said using the coarser grits he found leaves scratches that make it more difficult to sand out. He's been doing it for 20 years.
  4. Feb 6, 2024 at 6:21 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  5. Feb 6, 2024 at 6:24 PM
  6. Feb 8, 2024 at 12:18 PM
    Tridom
    Dominick
    Hampton Roads, VA
    I've tried off the shelf stuff in the past and had no luck. Wouldn't touch it.
    These were bad. You couldn't even see the orange light inside of it.
    Now they look like they just came out of the factory. (Only took 2 days to get this pic uploaded)
  7. Feb 8, 2024 at 12:24 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    tried several different methods with sand paper and polishing compound, tried mothers metal polish and that seemed to work well but sprayed compound al over everything. the fastest way I found was brake clean and a rag, You have to be careful and only wipe one way but it was fast and left a nice clear lens. have to try the cerakote next time
    Tridom[OP] likes this.
  8. Feb 8, 2024 at 1:19 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    To have them last after a restore, make sure they get a coat of UV sealer. There are a couple aerosol brands that work great, you can wax often, or apply some ceramic coating yearly. Mine have been getting restored for 10? years now, finally ready for new housings (lenses) due to microcracking.
  9. Feb 8, 2024 at 4:13 PM
    Tridom
    Dominick
    Hampton Roads, VA
    Yeah. I tried different compound also in the past and nothing seemed to work
  10. Feb 9, 2024 at 10:48 AM
    redrdr67
    redrdr67 New Member
    2007 White Tundra RCSB 2wd
    What brand is recommended for the UV sealer? Either aerosol or wipe? I've used two grades of rubbing compounds with great success, but the lens yellow/dull within a few months, not knowing about the sealer.
  11. Feb 9, 2024 at 10:50 AM
    Cerakote is working great for me
    redrdr67[QUOTED] and Penberrf like this.
  12. Feb 9, 2024 at 10:53 AM
    Penberrf
    Penberrf New Member
    2020 Tundra
    Looks good!
  13. Feb 9, 2024 at 10:53 AM
    VWTim
    Corvallis, OR
  14. Feb 9, 2024 at 12:43 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    How long since yours were done. I did mine 16 months ago and they are bad again. Would try something different if I figured I’d get difference results. Cause I already know I’m insane.
  15. Feb 9, 2024 at 1:08 PM
    16 months is a great run. Once a year would be fine with me. Mine have held up great for the last 4 months or so.
  16. Feb 9, 2024 at 1:13 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    VWTim[QUOTED] likes this.
