Got it off. Remove Electrical Connector on 06 Tundra ABS Actuator.
Discussion in '1st Gen Tundras (2000-2006)' started by Pat Miles, Jun 21, 2020.
  1. Jun 21, 2020 at 10:03 AM
    Pat Miles
    Pat Miles [OP] New Member
    Pat
    2006 Tundra 4 door, 4x4
    none
    I'm chasing a 2 amp continual draw problem which I have followed through pin 5 of the B fusible link in the main fuse box under the hood. The wiring diagram shows this lead powering the ABS unit on the passenger fenderwell under the hood.
    I need to remove the connector on the ABS unit to continue the chase but am unable to figure out how.
    Any and all help will be greatly appreciated.
    Thanks,
    Pat
    GOT IT OFF, the chase continues.
  2. Jun 21, 2020 at 5:32 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Make sure to report back with any findings.. :thumbsup:
  3. Jun 22, 2020 at 4:26 AM
    Professional Hand Model
    Hand Protectors
    Whats the secret technique to removal?
  4. Jun 22, 2020 at 10:17 AM
    Pat Miles
    Pat
    none
    Here is the unit with the connector locked in place.
    Note where the screwdriver is placed, pry the white locking piece upward.
    Pull the locking piece upward which will release the connector.
    To lock the connector back in place, push the connector back into the socket as far as it will go...do NOT try to force it all the way in.
    Next, while pushing the connector in, push down on the white locking piece at the same time. The locking piece will "cam" the connector into the socket while you are pushing it in. You might have to GENTLY tap the locking piece downward with a small hammer to get it to go down and fully lock the connector in place. TAP THE LOCKING PIECE SOFTLY WHILE PRESSING THE CONNECTOR INWARD!!!
  5. Jun 22, 2020 at 11:35 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    So is your and draw coming from inside the harness?
  6. Jun 22, 2020 at 12:00 PM
    Pat Miles
    Pat
    none
    Found that the alternator I replaced last summer was causing the draw, .32 amps constant. The alternator came from NAPA and will go back for replacement tomorrow.
    Found a broken sway bar/axle link broken while under the truck so that will be replaced also.
  7. Jun 22, 2020 at 2:55 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    My LS430 has a very similar connector for it’s ABS unit.. Might even be the same??:confused:
  8. Aug 8, 2022 at 7:36 PM
    junglesurf
    junglesurf New Member
    2006 Tundra DC
    Got it off! Thanks for the guidance.
    dbittle likes this.
  9. Aug 9, 2022 at 3:15 PM
    junglesurf
    2006 Tundra DC
    Sensitive ABS issue is gone but my check engine light is on and no speedo or odometer.
  10. Aug 9, 2022 at 8:11 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    What code comes up from the check engine light?
  11. Aug 9, 2022 at 8:54 PM
    junglesurf
    2006 Tundra DC
    P0500 no speedometer
  12. Aug 13, 2022 at 3:21 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Speedometer reads off of ABS wheel unit
  13. Aug 13, 2022 at 3:48 PM
    junglesurf
    2006 Tundra DC
    Thanks. Reconnected it and disconnected a speed sensor to disable the abs. I bought a reader that displays sensor readings but going to leave it disabled for now.
    HBTundra likes this.
  14. Oct 4, 2022 at 7:22 PM
    Cartour2020
    Cartour2020 New Member
    Charles
    Hi Guys, I know this thread has been here for a few months now. I was hoping someone can help me identify the "thing" in the picture? I want to move it so that I can install my auxiliary battery there.I used the picture posted here, hope that's cool. Thanks in advance!
  15. Oct 4, 2022 at 7:24 PM
    shifty` In South Dakota Trouble ain't hard to find
    EDIT: Wait, I'm on the wrong side of the truck. Just noticed the ABS brake spaghetti. It resembles the resistor for your fuel pump, but that's under the brake booster on the driver side.
    EDIT2: Looks like it's the fuel pump driver module, p/n 2308050150. Interesting. Wonder why in the hell it's on that side, when the resistor is on the passenger side? Reference photo here:
  16. Oct 4, 2022 at 8:50 PM
    Cartour2020
    Charles
    Oh wow that was fast, thanks Shifty! it looks like you are right on. Do you know if this thing must remain flat in order to operate correctly, I'd like to move it out of the way so that I can install my auxiliary battery tray there...
  17. Oct 4, 2022 at 9:25 PM
    NickB_01TRD
    Nick
    KY
    Seems most likely it could go anywhere but heat may be the problem. Those fins are designed to face up like that for heat dissipation. I believe it's a resistor.
  18. Oct 4, 2022 at 9:35 PM
    Cartour2020
    Charles
    Thanks a lot for your input NickB. I was thinking to relocate it within a few inches from its original location, just enough to make room for the battery tray. I'll try my best to keep it upright...
    NickB_01TRD[QUOTED] likes this.
