Got her running!
Discussion in '1st Gen Tundras (2000-2006)' started by Ob1kanukie, Jun 1, 2020.
  1. Jun 1, 2020 at 4:18 PM
    Ob1kanukie
    Ob1kanukie [OP] New Member
    06 Tundra SR5 Access cab V6
    Well hello again and hope that everyone is staying healthy and safe. Finally got her to run on Saturday and the engine purs like it should after a nightmare fix on a huge electrical short. Traced every line, checked for continuity, cut, solder, splice and patched it up. She's finally turning over. Last three items before she's road worthy 1. brake lines, can someone confirm the diameter of these brake lines that sit under the driver side. Will try and get OEM unless price is very dealership like. How much is it or is it just as good to go to Auto store and bend it yourself vs pre-bend line. 2. Other issue is the stuck hood. Cable is bad, can't tug on it and accidentally dropped the hood a little too hard and closed it. How do I get around that? 3. Last, is muffler from a 2017 interchangeable with 1st gen or only good from late 2nd gen to present? TIA
    bmf4069, BIGUGLY, MS22 and 1 other person like this.
  2. Jun 1, 2020 at 4:26 PM
    5ive7even
    5ive7even New Member
    Brett
    Nova Scotia
    silver 2007 regular cab long box sr5
    Leveled w/ Bilstein 5100, 1.5" spacers & rear airbags, factory alloys wrapped w/ 275/70r18 Goodyear Duratracs and a SS Magnaflow 12588
    WOWWWWW ... dude you're so lucky.
    nightmare is an understatement. really glad to see that you got through this one, it looks like it should have burnt to the ground
    Ob1kanukie[OP] and MS22 like this.
  3. Jun 1, 2020 at 5:10 PM
    Ob1kanukie
    Yeah was about two weeks worth of work and a lot of patience. Got the hood popped open just now, went from the underside, coat hanger and snaked it to the left over cable, pulled it down and got it to free up. glad there was enough of it left!
  4. Jun 1, 2020 at 5:13 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    WOW! Damn impressive! Not a chance in hell I’d tackle that job!
  5. Jun 1, 2020 at 5:16 PM
    5ive7even
    Brett
    Nova Scotia
    was was the cause of the electrical short? it looks like it melted down all of your wiring harnesses??
    MS22 likes this.
  6. Jun 1, 2020 at 5:19 PM
    5ive7even
    Brett
    Nova Scotia
    [/QUOTE]
    if I saw this I think id take it as a sign and just listen to the poor truck and push it off a cliff lol
  7. Jun 1, 2020 at 5:20 PM
    Ob1kanukie
    Me either! LOL, but my oldest project involves more wiring from an LS swap to an S2000, this prepared me for it mentally. That job will be way easier than this one! It's much worse toward the front of the tub connectors we're melted and wires fused together. So glad the fuse popped like it was designed to do.
  8. Jun 1, 2020 at 5:26 PM
    Ob1kanukie
    The owner I bought it from hot wired a battery charger for his RC airplanes to the truck, ran the cables through the main harness and hood cable section and this is the result of the short... Was going to use the old molding, cut out the bad section, plexiglass and glue in a new cover so you can see the repaired cables since the new piece I ordered is a lighter grey color.
    MTRock likes this.
  9. Jun 1, 2020 at 5:41 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    holy moly.... Good on you sir
    Ob1kanukie[OP] likes this.
  10. Jun 1, 2020 at 7:04 PM
    Ob1kanukie
    Thank you Aperezsh! Will be a great truck for us! Frame is still decent, 93k miles on it and everything works! Minus the said brake lines that needs to be replaced and hood latch. That's on order.
  11. Jun 1, 2020 at 8:03 PM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    if I saw this I think id take it as a sign and just listen to the poor truck and push it off a cliff lol[/QUOTE]
    x2
    aperezsh and Ob1kanukie[OP] like this.
  12. Jun 1, 2020 at 8:06 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    now you need to get some nice aluminum wheels for the thing
    does it have that wonderful burnt wire smell in it?
    Tundra2 likes this.
  13. Jun 1, 2020 at 8:38 PM
    Ob1kanukie
    Not that I can smell it, maybe my nose is toast! Been looking for new rims and tires, LED light bar and fog lights going on later. Glad we were able to save her with such low mileage it would be sacrilege to junk it. I do have to say, it's very frustrating looking for a replacement harness, for all of Toyota's infinite wisdom, they can't tell you what harness it needs even with the Vin #. So I had to go the route that I did.
  14. Jun 1, 2020 at 8:46 PM
    Ob1kanukie
    My next project... We're going Toyota based now from Honda's just to switch it up. If only we had more room to store cars! LOL
    So I found out a trick that seems to work for me... I buy these vehicles and then I give them to the Mrs and borrow them once in a while! Happy wife, happy life right right? She now has three vehicles and I only have 2 at the moment.
    G'nite to all cheers!
  15. Jun 1, 2020 at 9:03 PM
    empty_lord
    05 rollover special
    You don’t want to know how hard it was to find my tow package harness.
