Got code P144C
Discussion in '2nd Gen Tundras (2007-2013)' started by Capper, Sep 14, 2017.
  1. Sep 14, 2017 at 9:35 AM
    Capper
    Capper [OP] New Member
    2012 RW
    New owner of a 2012 RW flex fuel, bought from private owner. Just got it on the road yesterday so it's sat for a couple weeks besides me driving it around not far on the property. Sunday started it and got the dreaded cel, off trac & 4 lo flashing. Did some research, got a scangauge and was fully expecting to see the AIP trouble codes but no I got the P144C code. Scanner clears code but keeps coming back on, pretty quickly too.
    Been looking around a lot and don't see this code talked about on any Tundra forums. Checked the code listings/explanations I could find, don't see it there either. Closest is P0144 but that's not what I have. What I did find was Ford related and the possibility it may be a faulty purge valve.
    My thoughts are problem has to be around the evap canister somewhere as that is where I believe the purge valve is also. No manual etc yet. Got a new gas cap but not OEM, will check tubes, conns whatever around the canister. If I am heading in wrong direction would appreciate a nudge in the right direction.
    Thanks all
  2. Jan 13, 2018 at 8:10 AM
    Jaybird123
    Jaybird123 New Member
    ‘13 Tundra DC FF 5.7L
    JBA LT’s, BAM full exhaust w TRD pipes, OME 613
    Any chance you have a resolution/outcome to share? I have this exact same P144C code and CEL/Trac off/4Lo blink....anybody have suggestions?
    Thanks!!
  3. Jan 13, 2018 at 8:56 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca. Sorry, I don't have an answer for ya.
  4. Jan 13, 2018 at 12:12 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    Goggling:
    P144C - Evaporative Emission System Purge Check Valve Performance​
    Possible causes ​
      • Stuck open Evaporative Emission (EVAP) canister purge check valve (part of EVAP canister purge valve)
      • Damaged EVAP canister purge check valve
    P144C Description
    The Powertrain Control Module (PCM) tests the Evaporative Emission (EVAP) canister purge check valve for a stuck open condition. The EVAP canister purge check valve test is performed during minimal boost conditions, once per drive cycle, when entry conditions are met. The DTC is set if the fuel tank pressure exceeds a calibrated amount within a specified amount of time during the test.
    The canister is located between the fuel tank and rear axle
    NewImprovedRon and ColoradoTJ like this.
  5. Jan 18, 2018 at 9:46 AM
    Capper
    2012 RW
    That was my ques months ago. I researched and researched it and looked around engine just from the top though. Guess what it was: MICE. Little bastids had chewed into 2 wiring harnesses and were in the fuse box. I never saw any sign of MICE and I was looking but didn't open box like I should have. I was pretty sure the prob was those stinken pumps or possibly the driver. Stealership wanted half my house of course to fix but a buddy fixed the wiring harnesses and runs great now.
    NewImprovedRon likes this.
