Got any idea?
Discussion in '2nd Gen Tundras (2007-2013)' started by Law323, Oct 31, 2017.
  1. Oct 31, 2017 at 6:43 PM
    Law323
    Law323 [OP] it’s only weird if you make it weird
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    first off...I'm going to drive the truck to work tomorrow to see if it does the same thing, but until then, gonna see if anyone of you have an idea what went wrong.
    I'm bringing a buddy of mine home from work today, sticking with city streets. Takes about 20 minutes, afterwards when I'm on my way to my house, I hit the interstate. I'm on the merge ramp and go to speed up to my usual 70. I don't feel or hear the engine revving like I usually do. I look at the gauges...I'm going 65 and my RPMS are at 4000. I ease up, thinking I overdid it with the pedal. Slowly get up to 70....decide to try it again just to see what happened. I push the pedal to try to get up to 80....power drops to 65 mph and rpm goes back up to 4000. Felt like all the guts had been ripped out. No power, no rev, just whoooooo.
    I'm thinking a solenoid got stuck or the plugs need changing. Other than that, I have no idea.
    Maybe the tranny was cold, but I had been driving 20-30 mins before (not going above 50 though) and truck was sitting in 50 degree weather for 8 hours.
    Like I said, I'm gonna try it again tomorrow to and from work, but until then.....any ideas or anyone this has happened to before?
  2. Oct 31, 2017 at 6:52 PM
    250rdave
    250rdave like I told the guy on ABC DANGER IS MY BUSINESS
    David
    surprise az
    2014 blue trd dbl cab
    Borla cat back Airraid cai raptor grill pro comp at sport
    Pull the trans dip stick and smell the fluid if it has a burnt smell to it you may have lost some clutches also look at the color and level on the dip stick.I had a similar problem with my nissan titan low fluid ond burned up the over drive clutches
  3. Oct 31, 2017 at 6:58 PM
    It’s sealed trans
    Patriot, UTTundra and Law323[OP] like this.
  4. Oct 31, 2017 at 6:58 PM
    Bad fuel?
  5. Oct 31, 2017 at 7:04 PM
    250rdave
    David
    surprise az
    Bad fuel would give you a rough idle or like a miss our stumblig would also trip check engine light sounds more like a trans issue does the engine sound normal when you try to increase the throttle in netural or park?
  6. Oct 31, 2017 at 7:12 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Everything sounded and felt normal up until I tried to hit above 70. No problems with pickup power and acceleration below that speed.
  7. Oct 31, 2017 at 7:14 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Meant to include it's a 2012 4.6L 2wd. Just hit 70k miles
    GNTundra likes this.
  8. Oct 31, 2017 at 7:15 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Im grasping at straws here and I am not a Tech. Did you do the Zero Point Calibration after your lift?
  9. Oct 31, 2017 at 7:19 PM
    Makes me wonder if you have a fuel delivery issue or solenoid problem in the trans. I’m thinking fuel delivery though.
    Law323[OP] likes this.
  10. Oct 31, 2017 at 7:21 PM
    Were you uphill by chance?
  11. Oct 31, 2017 at 7:54 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nope. Flat terrain
  12. Oct 31, 2017 at 7:54 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Maybe something's clogged. Fuel injector?
  13. Oct 31, 2017 at 7:56 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    It's been over a year since the lift (6 months of spacer lift and 10 on BOSS) I'm no expert but I'd think I'd have noticed by now. :notsure:
    4x4_Angel and MotoTundra[QUOTED] like this.
  14. Oct 31, 2017 at 7:56 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    No flex fuel.
  15. Oct 31, 2017 at 8:18 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I agree. Curious to see what happens tomorrow. Good luck.
  16. Oct 31, 2017 at 8:37 PM
    Not sure, seems to me you are running out of fuel at high demand (more throttle for getting in the freeway).
  17. Oct 31, 2017 at 8:38 PM
    JimBeam
    JimBeam Moderator Staff Member
    South Carolina
    2015 Limited
    Sounds like it's time to upgrade!
    Law323[OP] and GNTundra like this.
  18. Oct 31, 2017 at 8:47 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    If you zoom in, you will see there is a small valve in the middle of the fuel injector that could be clogged.
  19. Oct 31, 2017 at 9:07 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    I would redo the ZPC. Sounds kinda like the traction control could be kicking in killing your power...
  20. Oct 31, 2017 at 9:17 PM
    250rdave
    David
    surprise az
    If you are trying to do highway speeds 65/70 and the motor is turning 4grand most likely have a trans issue.trans is not going into higher gear thats why the motors turning such high revs. If you had a fuel problem the motor would want to fall on its face. You can definitely feel a fuel issue
  21. Oct 31, 2017 at 9:18 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    That ......aint ......right
    TXMiamiFan[QUOTED] and 4x4_Angel like this.
  22. Oct 31, 2017 at 10:43 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I agree with @ColoradoTJ....I think fuel delivery to be the culprit. Could be injectors, but my first thought was fuel filter or fuel pump....which as ColoradoTJ noted might only be noticeable when fuel is at high demand. That said if it was a bad pump or the injectors, I think you could/would have some occasions of the issues at lower speeds.
    At 70K, if you've never changed the fuel filter, I'd start there. Once you run down the tank near E, change the fuel filer, fill it with Gas (no Ethanol) and add a bottle of injector cleaner.
    Good luck! :thumbsup:
    Law323[OP] and 4x4_Angel like this.
  23. Nov 1, 2017 at 1:39 AM
    brapp_kid7
    brapp_kid7 New Member
    Definitely check your trans fluid condition man!
  24. Nov 1, 2017 at 3:50 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    That is exactly what my boat was doing at the beginning of the season. Turned out to be a clogged injector.
    4x4_Angel, Law323[OP] and MotoTundra like this.
  25. Nov 1, 2017 at 4:16 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You don't have a fuel filter either. Take it out, see if you can reproduce the symptoms. If it happens again, pull the trans fill plug and jab your finger in there to see if you can get some fluid on it to do a sniff check for burned fluid. If you're able to rev to 4k rpms, I wouldn't think that there's a shortage of fuel. The biggest mystery in my mind is that your dash isn't lit up to indicate a fault.
  26. Nov 1, 2017 at 4:51 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    UPDATE:
    Ok, just drove to work. Now it feels like the engine doesn't want to get in gears 3 and above at the right time. It's especially worse when going up hills. I never go above 2500 rpm but this time around it just sticks in one gear and around 3000, it finally shifts. Weird shifts too. Sometimes when I let off the pedal, it downshifts. Doesn't feel harsh, timing just feels off and truck has lost its guts across the board.
  27. Nov 1, 2017 at 5:07 AM
    250rdave
    David
    surprise az
    Try this to rule out fuel system in park or netural let it idle then start to bring the rpm up do you hear or feel like the engine has a miss fire or any type of a stumble?
  28. Nov 1, 2017 at 5:14 AM
    250rdave
    David
    surprise az
    Do you have access to a code scanner auto zone ,O'Reilly 's, friend?
  29. Nov 1, 2017 at 5:22 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'll do that, it doesn't seem to be idling rough by any means but will rev it up to see what the deal is.
    Yes, that was my next step today after work.
  30. Nov 1, 2017 at 5:45 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I'm no help Law but good luck in getting this solved.
