Goodyear Duratrac RT
Discussion in 'Wheels & Tires' started by parkerbows, Oct 25, 2023.
  1. Oct 25, 2023 at 5:27 PM
    parkerbows
    parkerbows [OP] New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
  2. Oct 25, 2023 at 5:31 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    First time hearing about these. Are they lighter than the regular Duratracs?
  3. Oct 25, 2023 at 5:33 PM
    parkerbows
    Jack
    weight wise not sure. I actually had duratrac 275 70 18 ordered and then seen they were not winter rated. I cancelled and then seen these and ordered them. winter rated, kevlar reinforced warranty on lt size figured I would try. weird but 275 70 18 in regular duratrac excluded for winter rating
  4. Oct 25, 2023 at 5:42 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    That makes sense. Yeah duratracs are generally not great in the snow/ice on pavement. These new RTs look to have more siping which would help alot.
  5. Oct 25, 2023 at 6:25 PM
    parkerbows
    Jack
    yeab im hoping. not that we have been hammered with snow lately but never know. like trying different each time
  6. Dec 3, 2023 at 5:37 PM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Did you get 275-70-18 in the RT? I’m btw these and originals. The D rated on orig is still 3peak. How do you like so far?
  7. Dec 3, 2023 at 6:28 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I just put a set of SL rated 275/60R20s Duratrac RTs on our LX. We’ve only had them on for 400 miles or so. Just as quiet as my regular DTs. We’ll see if the Kevlar makes any kind of difference in tread wear or performance. Too early to tell.
    I’m on my 2nd set of regular Duratracs on my Tundra. They didn’t have the RT in LT285/75R18, so I stuck with regular Duratracs. I got 47k miles out of the first set, and I beat the snot out of them, so I can’t complain. 3 mountain peak snow rated in this size; never had any issues in snow.
    Pro tip, and I know I post this a lot on this forum: your Duratracs will stay quiet if you rotate them frequently.
    JLS in WA likes this.
  8. Dec 3, 2023 at 6:52 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    sidewalls on these look so much better than the regular Duratracs..
  9. Dec 4, 2023 at 3:14 AM
    parkerbows
    Jack
    i got 275 70 18 e rated. 3 peak rated. so far they are great
    Terndrerrr likes this.
  10. Dec 4, 2023 at 6:21 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Good looking tire. I’ve run a number of sets of Duratracs on my work vehicle and a set on my Tundra. They are very good in snow.
    I think you’ll be very happy with them. Keep them rotated and keep your alignment straight.
    parkerbows[OP] likes this.
  11. Dec 4, 2023 at 5:13 PM
    pro2amendment
    Indiana
    Bullet liner
    rotate front to back same side and back to front with switching sides?
  12. Dec 4, 2023 at 5:22 PM
    JLS in WA
    That's the pattern I follow. PR>PF>DR>DF>
  13. Dec 4, 2023 at 5:34 PM
    Terndrerrr
    Music City
    6UR-FE
    For RWD and 4WD vehicles, you’re supposed to do a rearward cross.
    Rears go to front on same side.
    Fronts go to opposite rear.
    The opposite cross, the forward cross is for FWD vehicles.
  14. Dec 17, 2023 at 8:45 AM
    pro2amendment
    Indiana
    Bullet liner
    Trying to find tire weights. Here is what I can find searching sites. I contacted Goodyear. Will update if I get answers. RTs are heavier than original. Videos from Goodyear indicated about 4-5lbs but not sure of size they were referencing. I’m replacing stock. The 275/70s are going to be a huge increase in weight.
    Duratrac RT
    275-70-18
    • 125R E: 60 lbs
    275-65-18
    • XL. 51 lbs, edit: saw Discount Tire lists as 48 lbs
    • E. 54-56 lbs
    original duratracs
    275-70-18
    • D: 54lbs
    • E: 55-58 lbs (two options)
    275-65-18
    • SL: 45 lbs
    • C: 49 lbs
    stock Michelin ltx
    275-65-18
    SL: 41lbs
    _none_ likes this.
  15. Mar 25, 2024 at 9:01 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    Bump
    pro2amendment likes this.
  16. Mar 29, 2024 at 8:24 AM
    pro2amendment
    Indiana
    Bullet liner
    Adding to the bump. Any updates or other people get?
    I plan to get the XL stock size when I get around to it. Still lil life yet on current. Plan to do before a summer trip
  17. Mar 29, 2024 at 8:38 AM
    blenton
    blenton New Member
    My shop neighbor has these on his new Super Duty. He drives more than I do and has a camper shell, bed slide, and bed full of gear like I do. We work a lot of the same areas and both see inclement weather and poor road conditions several months a year. He loves them - more so than the originals. In person, they do look more refined than the originals, and appear to have a more a optimized tread pattern with better siping which is a must in our neck of the woods.
    pro2amendment and JLS in WA like this.
  18. Mar 29, 2024 at 1:15 PM
    Terndrerrr
    Music City
    6UR-FE
    The Duratrac RTs on our LX570 have continued to do great. We’re closing in on 7k miles with them. I rotated them at 4k miles. Doing a 5 tire rotation.
    They are 275/60R20 in SL rating. 50.25 lb.
    Discount Tire says the regular Duratrac in this size has been discontinued. It was listed as being 49 lb in the same SL rating.
    Wish the RTs had been released in 285/75R18 before I put new tires on my truck in September. I would’ve gone with those instead of the regular Duratracs.
    Here’s a tread pic of each.
    Non-RT:
    RT:
  19. Mar 31, 2024 at 6:45 AM
    pro2amendment
    Indiana
    Bullet liner
    Found this for tire specs.
  20. May 7, 2024 at 9:12 AM
    overl4nd
    overl4nd New Member
    These don't seem to be 3PSMF rated in all sizes. Eg 285/75R18 is not 3 peak rated
  21. May 9, 2024 at 9:55 AM
    parkerbows
    Jack
    Just an update I have 275 70 18 rt. Have about 8k miles now. Still look brand new basically and balance still good, hardly any noise
  22. Jun 21, 2024 at 12:43 PM
    pro2amendment
    Indiana
    Bullet liner
    Just put on a set on Wednesday. I got the XL on stock size 275-65-18. Main reason was weight. 70s look to be close to 20lbs heavier ish than my Michelin original. It may have been just fine.
    I had two sets of Duratrac original on my lifted small xterra and loved them. Waited until I could get the rts near me.
    Anyways only have 15 miles so far lol so can’t post a legit review. wife thought I got bigger tires when she saw- just the impression they give.
    more to come later
    JLS in WA and _none_ like this.
  23. Jun 26, 2024 at 12:37 PM
    overl4nd
    overl4nd New Member
    I got 285/75R18 on the TRD Pro. No rub, but I don't think a similar size spare will fit!
    nasher75 and pro2amendment like this.
  24. Jun 26, 2024 at 2:47 PM
    Terndrerrr
    Music City
    6UR-FE
    It will. You may need to deflate it a bit (not a problem if you’re carrying onboard air) and/or bend the tabs out under the truck.
    overl4nd[QUOTED] likes this.
  25. Sep 19, 2024 at 9:02 PM
    roxysdad
    roxysdad New Member
    Gold Country, CA
    2021 DC MGM 4x4 SR5
    I decided to give these tires a go. Top needs/wants for me were the 3 peak rating, aggressive look, and reasonable weight. I haven’t messed with LT tires with my old truck, so I was really reticent to try them with the Tundra, so it was SL rating for me.
    Around town they have been great. I live in a hilly area with some weird slow turns up hill and these seem to have fantastic grip in the dry. Will see when the rains and snow come, but I’m hopeful with the 3 peak rating.
    I do hear a little too much freeway noise, but it’s nothing terrible. I’ll get used to it, and I hope it stays at this volume. I did a shake down trip of 600 miles last week and they ran great.
    Will report back in 5K miles or so!
  26. Nov 1, 2024 at 12:35 PM
    Usmchfd
    Usmchfd New Member
    2021 Tundra TRD PRO Luna rock
    None
    I just intalled 275/70/18 duratrac rt on my 21 tundra trd pro and look and feel great. Was wondering since they're E rated. What psi are yall running on these?
  27. Nov 1, 2024 at 8:21 PM
    blenton
    blenton New Member
    Referencing Load and Inflation tables, start around 42 psi. You should be +- 2 or 3 psi from there. I rant 42-47 psi when I ran LT275/70R18's and it worked well. 42 was a little squishy for my needs and I rarely needed more than 47 psi except when towing heavy.
    Usmchfd[QUOTED] likes this.
  28. Nov 1, 2024 at 9:43 PM
    Usmchfd
    Usmchfd New Member
    None
    Thanks, I'll experiment and see how they feel at 47.
  29. Nov 1, 2024 at 10:09 PM
    blenton
    blenton New Member
    I should have noted that with LT tires especially, a few pounds of pressure can make a big difference in ride feel. 42 psi is the corresponding pressure to the stock p rated tire size and pressure for factory load/handling/ride tradeoffs. I always have gear in the bed or a trailer in tow, so I prefer better load handling that would compromise ride comfort to a small degree. That tradeoff is up to you. But on the other hand, I've had tire guys tell me that I could run an empty truck at stock pressures or even lower (meaning 33 psi in the LT tire) and it wouldn't do a thing to hurt the tires. So feel free to experiment with the pressures a few PSI and see what works best for you.
  30. Feb 16, 2025 at 7:11 AM
    MrGreenGenes
    MrGreenGenes New Member
    How has your MPG been affected by the Duratracs?
