Good shocks for towing
Discussion in 'Suspension' started by Joemh69, Dec 21, 2021.
  1. Dec 21, 2021 at 7:43 PM
    Joemh69
    Joemh69 [OP] New Member
    Joe
    2018 Tundra 4X4 SR5
    Lifted
    Recommendations on upgrade to rear suspension for towing travel trailer?
    Stock shocks seem to ride low when towing.
  2. Dec 21, 2021 at 7:46 PM
    RobertD
    Robert
    DFW, Texas
  3. Dec 21, 2021 at 7:58 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Shocks don't control height. You may need heavier shocks, but that is rear springs. There are many options, but none are shocks alone.
    snivilous and landphil like this.
  4. Dec 21, 2021 at 8:12 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    As stated above, shocks don't control height.
    If you are squatting when hauling, there are a few things to look into.
    Weight distribution hitch, properly set up. I highly recommend this no matter what you do, and also make sure you get away control.
    Air bags. I prefer with an automatic leveling kit installed. Very helpful as it automatically adjusts to your preferred ride height empty/hauling stuff in the bed/towing.
    Add a leaf or aftermarket spring set. You will get better quality ride with a new aftermarket spring set than you will an add a leaf.
  5. Dec 22, 2021 at 7:54 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    You may also want to get some trailer/hitch weight rating info about your truck and the trailer fully loaded to compare. Trucks will squat with a heavy load, and thats ok. You just want to make sure its not overloaded beyond its limits. If you are in fact overloaded for that leaf spring/shock setup, there are replacement options like discussed above. Just keep in mind how often you drive the truck without the trailer vs the time you do tow. You may have to compromise daily driver comfort with towing performance. Just some things to think about
  6. Dec 22, 2021 at 9:21 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Shocks only dampen, they do not provide support.
    check out RAS- activesuspension.com Perfect for what you need.
    Also add the TRD rear sway bar
