Good afternoon fellow tundras my name is James Dean tundra and lightning
Discussion in '1st Gen Tundras (2000-2006)' started by TundraNLightning, Dec 16, 2020.
  1. Dec 16, 2020 at 2:47 PM
    TundraNLightning
    TundraNLightning [OP] New Member
    James
    2000 WHITE ACCESS CAB TUNDRA
    4" lift
    Okay so I got a 2000 white Toyota tundra access cab 4x4 I put a 4-in lift on it and just about 2 days ago I noticed it started vibrating at about 20 mph up to about 30 mph and it's been progressively getting worse as the miles get put on it anybody have any idea or give me any tips on what to do I'm pretty well mechanically inclined I'm building a 1987 Toyota 4Runner right now matter of fact my auto parts store gets parts for it as I'm driving my truck is vigorously shaking please help I know tundras enlighten me with some knowledge and wisdom
  2. Dec 16, 2020 at 2:48 PM
    Welcome from NY.
  3. Dec 16, 2020 at 2:52 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Welcome.
    If it were me, I’d crawl underneath it and visually inspect everything. Next, check wheel bearings and make sure tires are within balance.
  4. Dec 16, 2020 at 4:01 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    +1
    We'll need better analytics, or we're just guessing.
    Mine is that after you did a 4 INCH lift you prolly stressed the front axles a scoche.
  5. Dec 16, 2020 at 4:04 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Dec 17, 2020 at 8:47 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    4 inches is pretty high on these trucks. What type of lift? Did you get it aligned after? Check all of your u joints on the driveshaft and especially the carrier bearing.
    Schcoman likes this.
  7. Dec 18, 2020 at 7:09 AM
    What lift is this? Is it a new front cradle type that relocates the lower control arms and has new or lengthened spindles? Or just spacer / coil / upper A arm with no cradle? 4" is beyond what the factory geometry will reasonably allow. 3" is pushing it. RCD has a 6" and I believe TC has a 4.5" maybe? that use a new front cradle to relocate the lower arms. The front diff needs to be lowered to match the new angles up front. Regardless, the lift will change the angle of the drive shafts, both front and rear and could exacerbate a failing part, such as a bad U-joint. The rear lift, if done improperly, can severely change the rear pinion angle and cause issues with the joints. More info / pics would be helpful.
  8. Dec 18, 2020 at 7:13 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania!
  9. Dec 18, 2020 at 7:14 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    An '87 rust free 4Runner? Now that's awesome if so. Love those. Welcome, and hope your problem gets solved. Great group here!:thumbsup:
    Darkness likes this.
