Going to be changing the “bead lock” bolts on my Method Double Standards
Discussion in 'Wheels & Tires' started by bmcdds, Dec 2, 2018.
  1. Dec 2, 2018 at 9:54 PM
    bmcdds
    bmcdds [OP] New Member
    CA
    2019 Barcelona Platinum
    These are with the zinc bolts. I purchased the black kit, and I’m debating on painting a zinc set in 3R3 to see how’ll look color matched to the truck.
    Anyone have any advice on how to switch them out without scratching the wheels?
    Mountun Goat likes this.
  2. Dec 2, 2018 at 9:58 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Use thin walled socket..and take your time.
  3. Dec 3, 2018 at 7:24 AM
    bmcdds
    CA
    Thanks. I was thinking the same thing. I'm hoping someone could point me to some magical socket that is hard enough to torque them down properly, but not hard enough to scratch the wheels. ;)
  4. Dec 3, 2018 at 7:43 AM
    saybng
    Gary
    Ventura CA
    Use the same socket, doesnt need to be torqued down to much..
  5. Dec 3, 2018 at 7:51 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I’m doing this soon when my bolts arrive, I’m thinking lay over some cling wrap first and/or stick bolt spacers inside the socket to make it shallower enough not to touch the wheel finish. Ideally I’d like to loosen them all off with an impact driver, but I’ll hand apply the new ones with a socket wrench.
