Going from 4Hi to 4Lo requires stopping?
Discussion in '2.5 Gen Tundras (2014-2021)' started by LTundra, Oct 8, 2021.
  1. Oct 8, 2021 at 3:56 PM
    LTundra
    LTundra [OP] New Member
    I just bought a 2018 Tundra Limited Ed. I was reading in the owners manual that to go from 4Hi to 4Lo, you have to stop, shift in to neutral and to got 4Lo.
    This seems to be several years behind in tech, sort of like stopping, getting out of the vehicle, and twisting the wheel hub.
    Is this correct, you have to stop and then go to Neutral and switch?
    Thanks!
  2. Oct 8, 2021 at 3:59 PM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    Yep, seems normal to me --- that is to keep those without commonsense from shifting out of 4 HI at 50mph into 4LO -- bad things happen
  3. Oct 8, 2021 at 4:06 PM
    LTundra
    I've had instances where I was going uphill and needed to move from 4Hi to 4Lo, at a very slow MPH, but to have to completely stop, go to neutral and 4Lo would make the vehicle lose momentum that is needed to keep moving without starting off spinning again. That's why it seems strange to me.
  4. Oct 8, 2021 at 4:06 PM
    CTundraForMe
    CTundraForMe New Member
    What he said.
    Frankly I'm impressed you can shift from 2H to 4H up to 62mph!
  5. Oct 8, 2021 at 4:07 PM
    CTundraForMe
    True that. In those cases you start in 4L at the bottom of the last dip.
  6. Oct 8, 2021 at 4:19 PM
    For the hills you mentioned, you just start in 4Lo and crawl up. Less wear and tear. Normal 4x4 operation in my experience, as I don't think I've ever driven anything with a 4Lo that could be engaged on the fly.
  7. Oct 8, 2021 at 4:47 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    It’s been my experience a 4LO situation rarely ever involves speed and momentum. Every truck I’ve ever owned required me to stop and go to N to engage 4LO.
  8. Oct 8, 2021 at 5:11 PM
    LTundra
    Maybe so. I guess I have had this situation occur so few times maybe I'm not remembering that I actually had to stop to go to 4Lo. Anyway, I see the point. Follow the guide.
    Ely010606 likes this.
  9. Oct 8, 2021 at 5:15 PM
    2mchfun
    I'm still struggling with why mine won't grab reverse in 2Hi while the cruise is set at 80. It only works when I stop first and then change gears. So difficult!!
  10. Oct 8, 2021 at 5:16 PM
    Darth_cholo
    Darth_cholo New Member
    probably better that if you can't get traction, backup, switch to 4low then begin the climb again with your momentum.
    Dr Doobie likes this.
  11. Oct 8, 2021 at 5:26 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Just be happy if it actually goes into 4 low. :laughing:
  12. Oct 8, 2021 at 5:55 PM
    2mchfun
    Hey OP, seriously, do yourself a favor and exercise that stop-neutral-4lo-neutral-4hi-2hi routine on a loose surface minimum 12-15 times per year. Get in a few miles during each exercise. If not, the actuators may stop working leaving you SOL.
  13. Oct 8, 2021 at 5:59 PM
    Blue Thunder
    Washington
    Stopping to drop into 4H is old tech, stopping to go from 4H to 4L is normal. I've owned multiple Fords, GMCs and Nissan trucks in the past 20 years and they're all like that. It is more than just engaging the front driveline, you've got to change the gears in the transfer case.
  14. Oct 8, 2021 at 6:25 PM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    I’ve heard a truck go from 4H to 4L while moving once. It rocked backwards as it was engaging. Sounded like a spoon in a garbage disposal and he needed a new transfer case, not a fun sound.
  15. Oct 9, 2021 at 8:39 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Ram is on the bleeding edge of tech and even my 2019 2500 required you to stop, shift to neutral, and then shift to 4 low. Totally normal operation for a 4x4. My Tundra is a much better daily driver than any Ram.
  16. Oct 10, 2021 at 5:26 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Usually while starting to sweat and thinking “ oh crap, don’t be stoopid, turn around.”
    JLS in WA[QUOTED] likes this.
  17. Oct 10, 2021 at 6:29 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Mine will go into 4lo easier if I engage 4hi first.
  18. Oct 10, 2021 at 6:55 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I can not recall any 2 speed transfer case equipped trucks that did not require stopping to shift into low range?
    JLS in WA likes this.
  19. Oct 10, 2021 at 7:28 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Follow the instructions of the Manual
  20. Oct 10, 2021 at 7:30 AM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    This will not be a 8ssue on the 2022
  21. Oct 10, 2021 at 9:27 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I had a college roommate that had a Olds Jetstar with a 394. That thing was a beast. One day on the toll road in PA going 70 mph one of his backseat passengers hood on a coat hooked on the T shifter. He pulled it and dropped it in to 1st gear. I was surprised it did not blow up.
