Going back to stock-ish?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TRD PRO 17, Aug 29, 2024.
  1. Aug 29, 2024 at 7:04 AM
    TRD PRO 17
    TRD PRO 17 [OP] New Member
    Tyler
    2015 Inferno Crewmax TRD PRO
    Looking for some opinions/thoughts...
    I've got a 2021 PRO & currently am running the full coachbuilder setup with his steering kit & aftermarket JBA UCA's. I previously had a 2015 PRO with just his shims & shackles with no drivability issues at all.
    I'm going to be putting the stock outer tie rods back on, simply for ease of maintenance and to be less of a hassle when alignments are needed etc..
    So, what are your thoughts on just having the stock UCA's put back on at the same time as well? Or would you just let the JBA's ride?
  2. Aug 29, 2024 at 7:29 AM
    rcsbguy
    rcsbguy New Member
    No leave the UCA on. Why take them off?
  3. Aug 29, 2024 at 8:37 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I was going to convince you not to take them off, but if you are, sell 'em to me lol.
    TRD PRO 17[OP] likes this.
  4. Aug 29, 2024 at 8:54 AM
    TRD PRO 17
    Tyler
    Honestly just to simplify things.
  5. Aug 29, 2024 at 11:27 AM
    rcsbguy
    rcsbguy New Member
    Do you have any lift at all? If so, going to stock uca’s will hurt rather than help
  6. Aug 29, 2024 at 11:34 AM
    TRD PRO 17
    Tyler
    Standard TRD pro fox setup with an extra 1" from the strut shims. So, within range of what the stock UCA's can handle. I just added the JBA's at the time for the added castor built in, but weren't necessary.
  7. Aug 29, 2024 at 11:35 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    If there’s no lift, and you just want to swap back out to OEM, go for it.
    All it is your time and money if you decide to. Doesn’t hurt anything at all. Should be fairly simple to uninstall, plenty of videos for you to watch on how to remove UCA.
    Although you are going to be required to go and do an alignment again to get everything to factor spec once the change is done - otherwise expect wear on tires immediately.
  8. Aug 29, 2024 at 11:37 AM
    TRD PRO 17
    Tyler
    I'm running the stock TRD pro fox setup with an extra 1" from the strut shims. Which is realistically within the range of what the stock UCA's can handle. I just added the JBA's at the time for the added castor built in, but weren't necessary.
    Know that for sure about the alignment.
  9. Aug 29, 2024 at 11:43 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Those are the CB shims right?
  10. Aug 29, 2024 at 11:43 AM
    TRD PRO 17
    Tyler
    Yeah, they are.
  11. Aug 29, 2024 at 11:45 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Not much trouble to remove then.
  12. Aug 29, 2024 at 11:46 AM
    TRD PRO 17
    Tyler
    I'm leaving the shims and the shackles, not messing with those.
  13. Aug 29, 2024 at 1:09 PM
    rcsbguy
    rcsbguy New Member
    Will with the shim, the uca gives you extra adjustability which oem does not. Unless the balljoint is shot, just keep it on there. My thought.
