Go Rhino RB20 running boards noise??
Discussion in '2.5 Gen Tundras (2014-2021)' started by yel911, May 13, 2021.
  1. May 13, 2021 at 7:48 AM
    yel911
    yel911 [OP] New Member
    NH
    2018 Crew Limited
    I don't know if I ever notice before, but since I installed these running boards I hear creeking noises. Never mind hearing every pebble that hits them.... I never noticed any of this with the OEM Toyota running boards, which were plastic and aluminum. Anyone?
  2. May 13, 2021 at 7:59 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I've never noticed it on mine. Are the boards up against something so when the truck flexes it creaks?
  3. May 13, 2021 at 8:55 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Make sure your bolts are tight. May want to check your skid plate if you have one, they can creak and squeak, pretty common as well.
    yel911[OP] likes this.
  4. May 14, 2021 at 2:45 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    The only complaint I have with mine is that some of the powder coating is chipping away and allowing some surface rust to form. The price you pay for living in the rust belt. BTW, RB20's have gotten ridiculously expensive.
  5. May 14, 2021 at 4:31 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Nope...mine are fine...never hear anything.
  6. May 15, 2021 at 8:02 PM
    Albino Predator
    Albino Predator New Member
    2020 White Tundra
    Just installed mine. Came with a cracked seam. Getting that one side replaced. Haven't heard any noise from boards.
  7. May 17, 2021 at 9:36 AM
    yel911
    NH
    2018 Crew Limited
    Good idea!! I do have a TRD skid plate... never thought about that making the noise. Thanks!!!
