Glove box removal…?!
Discussion in '2nd Gen Tundras (2007-2013)' started by Hilandr, May 23, 2022.
  1. May 23, 2022 at 3:00 PM
    Hilandr
    Hilandr [OP] New Member
    2011 Tundra SR5
    I cannot for the life of me find instructions or a video for removing the glovebox on my 2011 SR5. Anyone?? I can’t even figure out how to get the cover off below the airbag.
  2. May 23, 2022 at 3:24 PM
  3. May 23, 2022 at 3:41 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    As I recall you just open it and then push in the sides by the dash so clips clear. Then it should swing freely from the hinges and I recall it was obvious from there.
  4. Jun 9, 2022 at 10:01 AM
    Heyyouintheriver
    Heyyouintheriver New Member
    Very near Mt. Rainier
    2010 Dbl 5.7 145k bought it 7/21 for 18k
    Color mismatched LEER canopy, cheap running boards, LED reverse lights so nobody can stand behind and direct me
    Hilandr! Did you figure it out. I wanted more access to look at my 4wd ecm and wondered if i could pop out the lower glove box without taking out the airbag. On mine there are only two screws inside the door up at the top. I see people talk about unhooking a piston (I don't have a piston visible) and "pushing in on the sides" which is a non starter as well. Just wondering if you went through any of this?
  5. Jun 9, 2022 at 11:52 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Open glove box. On right side, pull off the damper rod. At the top, grab the box on both sides and flex inward where the stops are and the whole thing will pivot out and release of the hinges.
  6. Jun 9, 2022 at 2:22 PM
    Heyyouintheriver
    Yeah Frichco228 I think that is for a gen2.5 I have a 2010 grade and there may be a piston but not in my glovebox line of sight. I will keep looking for one though, thanks.
  7. Jun 9, 2022 at 4:42 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I have not ever actually pulled mine but I just poked around and here is my best guess.
    Step 1: pull the door sill trim
    Step 2: pull the kick panel
    Step 3: there is a 10mm bolt holding the lower dash panel in
    Step 4: you have to remove the panel up underneath the dash that is held in by panel clips
    Step 5: pop off the lower dash panel (there MAY be another 10mm on the radio side of the lower dash panel but I can't see it without performing step 4), the airbag should stay there in place and has its own bolts holding it in place
    Step 6: there are two screws on the top edge of the lower glovebox
    Step 7: the glovebox should pull out towards the seat with some panel clips
  8. Jun 10, 2022 at 9:59 AM
    Heyyouintheriver
    Damn Brandon you are the man! I have done all this except for removing the panel that surrounds the passenger airbag module. That is think is the #4 10mm bolt you mention. I was always seeing the "grasp the piston" advice and it must have been gen2.5. Thanks a bunch and I will Def pay this forward/update if the box is just held in by clips once i remove #4. Hoping not to mess with airbag module.
  9. Jun 10, 2022 at 10:21 AM
    APalmTree
    Brandon
    SW Washington
    The 2.5 gens are a little different, the "door" actually is the container. So everything actually moves with the door when you open and close it, hence the need for a little assist strut. Ours the door closes on the "shelf" where your stuff actually sits and has no strut or piston in it.
