Getting ready to buy wheels and tires
Discussion in 'Wheels & Tires' started by Madshadow, May 14, 2016.
  1. May 14, 2016 at 7:07 PM
    Madshadow
    Madshadow [OP] New Member
    Tom
    Indiana
    2013 SR5 TRD 5.7 4x4 double cab
    Westin HDx brush guard. 2" rivet style fender flares. 5" oval running boards.
    Hello, I am getting ready to buy tires and wheels tonight! I have a 3" leveling kit installed. I also have 2" fender flares. I am wanting to buy 18x10 XD Series wheels with a -24 offset and 33x12.50 tires. I am hoping they will stick out far enough to match my fender flares. Will these fit ok? Can I go bigger? Thanks!
  2. May 14, 2016 at 7:57 PM
    Ubc2361
    Ubc2361 New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    You could go bigger. I have 285 70 18. Basically 35s no problem. Also with xd rims
    TheBeast likes this.
  3. May 14, 2016 at 8:19 PM
    Madshadow
    Tom
    Indiana
    Thanks! Do you have you know the offset of your rims? Also are your rims 9" wide or 10".
  4. May 14, 2016 at 8:27 PM
    Ubc2361
    Ubc2361 New Member
    Tony
    Los Angeles
    9 wide 25mm offset
  5. May 14, 2016 at 8:38 PM
    Madshadow
    Tom
    Indiana
    Negative 25 correct? What size lift kit do you have? Wonder if 10" wide rims will be ok?
  6. May 14, 2016 at 8:40 PM
    Ubc2361
    Ubc2361 New Member
    Tony
    Los Angeles
    I have bilstein 5100 leveling kit. 2.5 inch lift so it says
  7. May 14, 2016 at 8:46 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    What wheels are you looking at? -25 is to much imo. I have -20 and 35/12.50 and I think they have to much offset. I have a set of xd monsters I'll make ya a deal on.
  8. May 14, 2016 at 8:49 PM
    Madshadow
    Tom
    Indiana
  9. May 14, 2016 at 8:50 PM
    Madshadow
    Tom
    Indiana
  10. May 14, 2016 at 8:54 PM
    Virgils12
    Going with a 12.50 wide tire between +30ish to +18. If you go -25 your gonna be 3" or maybe a little more past your fenders.
  11. May 14, 2016 at 8:54 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Stock wheels are +60.
    +20 gets you close to the edge of the fenders depending on tire width of course.
    I have wheel spacers that put me at +18.24. Perfect IMO. Sticks out about an inch or so.
  12. May 14, 2016 at 8:57 PM
    csuviper
    Broomfield, CO
    Measure the distance from the tire to the outside edge of the fender. I will figure out what offset puts you out 2" from the fender.
  13. May 14, 2016 at 9:05 PM
    Madshadow
    Tom
    Indiana
  14. May 14, 2016 at 9:23 PM
    Madshadow
    Tom
    Indiana
    Looks like just under 3" form the edge of the tire to the edge of my fender flares. I have stock p285/65r18 tires. On stock rims. I want the new tire to match or stick out a little past the flares.
