Getting proper distance with retrofits
Discussion in 'Lighting' started by DustinP5, May 18, 2018.
  1. May 18, 2018 at 6:45 PM
    DustinP5
    DustinP5 [OP] New Member
    Austin, TX
    2015 Magnetic Grey SR5 Crewcab
    Retrofit Headlights, Heated/Cooled leather seats, Leveled, Pro Grille, Wireless counsel charger, TRD Shif Knob
    Alright guys, I recently leveled my truck and want to make sure I’m getting the right distance with my retros, but also not blinding other drivers. I’m 45’ away from the wall and the middle of the cutoff line is 48” tall. Is that too high?
  2. May 18, 2018 at 6:46 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You need to lower your right projector
    Both should be at the same height
  3. May 18, 2018 at 6:53 PM
    DustinP5
    Austin, TX
    Like this?
  4. May 18, 2018 at 6:55 PM
    Danimal86
    Daniel
    Sacramento, CA
    Perfect!
    As far as the right height, just use the leveling motor to adjust the height while driving
    DustinP5[OP] and Pudge like this.
  5. May 18, 2018 at 7:28 PM
    DustinP5
    Austin, TX
    Cool, thanks man! I didn’t know if there was some kind rule of thumb with distance and height
  6. May 18, 2018 at 7:30 PM
    Danimal86
    Daniel
    Sacramento, CA
    Nope, I just found a sweet spot when driving at night for the first time with projectors.
    DustinP5[OP] likes this.
  7. May 18, 2018 at 7:51 PM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    There is a “standard” way of doing it, something like 3” drop over 25’. But that’s more applicable for a car or other low vehicle. For vehicles with the lights higher off the ground like our trucks, especially yours now that you’re lifted, get it close and get the projectors even, then find the sweet spot with the motors while you’re driving. Once you find the sweet spot, you can mark/tape off where it is on a wall, rise the lights to zero, then adjust down the lights to your mark. This will set the max height. Or just leave the motors at whatever setting. Hope this helps/makes sense.
    Edit: it’ll probably take a few days to find the sweet spot, so no rush getting it dialed in. I wouldn’t “rezero” until you’ve driven and tested for a few days.
    4Runner and DustinP5[QUOTED][OP] like this.
  8. May 18, 2018 at 8:29 PM
    DustinP5
    Austin, TX
    Of course it helps, any info/knowledge given is useful to me
    4x4_Angel likes this.
  9. May 18, 2018 at 8:57 PM
    GreatAvalon
    Ok cool, sometimes I can suck at explaining things :D
    Your retro output looks like it turned out great by the pics. Look like RX350 or MLED projectors?
    DustinP5[QUOTED][OP] likes this.
  10. May 18, 2018 at 9:59 PM
    DustinP5
    Austin, TX
    Thanks, they are MLED and they turned out great!, very happy with the whole build
  11. May 20, 2018 at 7:40 AM
    jro05065
    jro05065 New Member
    Denver
    2017 CM Tundra TRD
  12. Oct 19, 2019 at 6:28 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    I’m needing the same help. I’m 25ft away and the black tape marking is 48” high or so. I felt it was a little too high for me I’m sitting on a leveling bilsteins 2.5” I need to adjust more to side but have to remove the whole grille to reach that part. Going to wait.
