Getting Power to the Bed
Discussion in '2.5 Gen Tundras (2014-2021)' started by TR15UCK, Mar 31, 2023.
  1. Mar 31, 2023 at 5:35 AM
    TR15UCK
    TR15UCK [OP] New Member
    2020 Cement Limited
    Morning all:
    I'm not even sure what to search for to see if this is possible, so here's a new thread. I have a 2020 with a cap, and I'd love to somehow run power to the bed so I could plug in tools/batteries to charge off of my truck. Is this even a thing?
    I'm handy enough that I've done most of my mods myself, but never messed with electrical to that extent. Any suggestions?
  2. Mar 31, 2023 at 5:41 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    You just need to run an inverter from the battery to the bed of the truck.
    I would recommend running it through a switch in the cab so it's only on when you want it to be.
    TR15UCK[OP] likes this.
  3. Mar 31, 2023 at 5:42 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Search bed power and click the box that says “search titles only”. Loads of threads come up. And good luck
  4. Mar 31, 2023 at 5:44 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Sounds like you want AC power to run tools. You can install up to a 1000 watt power inverter, the stock alternator should be able to supply enough juice to it.
    TR15UCK[QUOTED][OP] likes this.
  5. Mar 31, 2023 at 6:05 AM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    Lots of folks on here have done it lots of different ways. You need to determine how much power you want/need, then figure out how to tackle it.
    I'm running a 10g wire fused at the battery down the driverside frame rail up behind the driverside tail light. The run is 16-20' so should be good for about 15 amps (enough for my needs). I plan to add a 12v panel that I could plug a small inverter into if needed.
    Some guys have put an inverter in the cab, and run a 120v plug cut into the bed.
    Some are running a massive 0ga to be able to run a rear winch.
  6. Mar 31, 2023 at 6:39 AM
