Getting my Limited to sit like a Pro?
Discussion in 'Suspension' started by Derna, Dec 29, 2017.
  1. Dec 29, 2017 at 6:00 PM
    Derna
    Derna [OP] New Member
    My Nightmare 2018 Inferno TRD Limited
    So my husband has a 2016 Tundra Pro, i just purchased a 2018 tundra limited with the added TRD package. I want my truck to sit like his does and unsure if i need just a leveling kit or a lift or both. I called the parts/service dept of the dealership i purchased from and they told me thr Pro has a 6 inch lift ( i dont think so) and it would be $4,000 . Then i called another dealership and asked the same thing, they told me i just need to change out the shocks. about $700. In my opinion i think i only need a 2 inch lift, but want to know form all you experts what your suggestion is.
    thanks
    AxelsHumanDad and Marty McFly like this.
  2. Dec 29, 2017 at 6:02 PM
    If it’s a stock pro lift, it’s about 2” of height. Shocks don’t change your height- spacers or coilovers (the right way, IMO) will.
  3. Dec 29, 2017 at 6:04 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome!
    :worthless:
    Derna[OP] likes this.
  4. Dec 29, 2017 at 6:05 PM
    Welcome from Ohio!:worthless:
  5. Dec 29, 2017 at 6:08 PM
    ToyotaTundraMike
    2015 Tundra
    The pro sits at 2”. Get a leveling kit and you will be fine. Never go back to the place who told you the pro is lifted 6”.
    AggiePhil, 15whtrd, drhntr and 8 others like this.
  6. Dec 29, 2017 at 6:14 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx Derna. Sean is exactly right. It depends on what your gonna do with your Tundra. You going off-road a lot, then full coilover kit from Toytec will get you where you need to be. If you are mainly keeping it on the flat then a spacer will be fine. I've been running a 2 1/2" spacer for 2+ yrs with no problem. Make sure it's a billet solid aluminum. I wouldn't mess with any mild steel spacers. Some of our lift pros will chime in at some point. :thumbsup:
  7. Dec 29, 2017 at 6:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    One up your husband and get a 3” lift. :p And welcome to the site.
  8. Dec 29, 2017 at 6:19 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ. The trd pro has 2" lift in the front end. The TRD pro coil overs and rear shocks will cost you around $2,300.00 then labor to have them installed. There are other options that cost way less and do the same thing.
  9. Dec 29, 2017 at 6:35 PM
    Like everyone mentioned^^^^...there are so many factors that come into play...Call ToyTec................................they have all kinds of options and lots of knowledge.
    T-Rex266 likes this.
  10. Dec 29, 2017 at 6:39 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Don't use a spacer lift. Use new Coil overs.
    Smiley, 15whtrd, jjstu123 and 2 others like this.
  11. Dec 29, 2017 at 7:01 PM
    Welcome from Texas!
  12. Dec 29, 2017 at 7:11 PM
    If you’re going the spacer route, I would suggest the in-coil spacer kit.
    equin likes this.
  13. Dec 29, 2017 at 7:11 PM
  14. Dec 29, 2017 at 7:27 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  15. Dec 29, 2017 at 9:07 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Revtek 2.5 inch spacers ...... THE ONLY TOYOTA APPROVED SPACER KIT !!!!
    Sunnier likes this.
  16. Dec 29, 2017 at 9:11 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    If you research the Revtek spacer kit, you will see how it is installed, and will see the engineering behind it....it is different than the other spacers out there !!!
    Black Wolf and 831Tun like this.
  17. Dec 29, 2017 at 9:19 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    The billet Aluminum spacer is placed inside the coil pack. But there is also another spacer that is placed on top of the coil pack, thus taking the stress off of the suspension, which all the other spacers out there don't do. That's why Revtek is the only spacer kit that Toyota approves ! I did my research before i put it in my truck :thumbsup:
    Sunnier and 831Tun like this.
  18. Dec 29, 2017 at 9:20 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    20170315_165934.jpg.....if you look real close you can see the "round" billet type washers that sit above the big spacer...this set up takes the "stress" off the suspension....of course it's not anything like coilovers...but I dont off-road anymore....very inexpensive if you want the truck leveled and are going to be a pavement princess :D
    seniramsu, Black Wolf and 831Tun like this.
  19. Dec 29, 2017 at 9:31 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    What brand spacers do you have Ron ?
  20. Dec 29, 2017 at 10:15 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon!
  21. Dec 30, 2017 at 4:49 AM
    rons23
    Ron
    Kill Devil Hills
    Supreme Suspensions Scott. Got them for 69.99. Solid Bill
    Got them from Supreme Suspensions here's the link. They were only supposed to be temp, but life changes. Here's the link .
    http://supremesuspensions.com/
    Black Wolf likes this.
  22. Dec 31, 2017 at 3:31 PM
    Derna
    Thanks everyone, tight now I think I'm just going with a leveling kit, I don't do offroading, but with that being said to get to my house in the national forest I drive a 13 mile gravel road down the mt and back up daily.. maybe when I replace tires I will go with a bigger tire and 2 inch lift.
    Eclipsed & Floating likes this.
  23. Dec 31, 2017 at 3:42 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I did the 3/1 lift and level from lowrangeoffroad.com. More than happy with the setup and ride
  24. Mar 10, 2018 at 5:48 AM
    Marco
    Marco New Member
    I used 2.75 aluminum spacers over stock
    And after 3 months the ride and handling
    Became scary .
    I went with 2.50 quick lift 999919/20
    And 5000 on rear Rancho and upgraded
    To platinum 20 on 275 65 20 nokkian
    41.5 front 42” rear
  25. Mar 10, 2018 at 8:03 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    what stresses do you think are being eliminated here? It's effectively creating stress risers by concentrating the entire suspension load on a significantly smaller surface area of the 3 washers you pointed out.
  26. Mar 10, 2018 at 8:05 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    Research the brand
  27. Mar 10, 2018 at 8:08 AM
    the_midwesterner
    Luis
    None, yet....
    I did. Noting on their site that says contrary to the fact that these are just shinier spacers.
  28. Mar 10, 2018 at 8:22 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    Go to "Off-Road.Com" ....."Revtek 3 in. lift Review @ Offroad.com".....Explains WHY Revtek is different than the other spacer companies out there ....I could spell it out for you, but I'm not going to....read it ....Toyota only approves Revtek for this reason...Spacers are NOT for OFF ROADING....But of course MOST people who own trucks know this ....
    15whtrd likes this.
  29. Mar 10, 2018 at 8:39 AM
    the_midwesterner
    Luis
    None, yet....
    So it’s obvious that your are getting upset by me 2nd guessing the statements you are making on here. So I’ll let you be.
    I do want to clarify a couple things for the rest. Sure spacer lifts work, but they are still spacer lifts. Nothing revolutionary, except that instead of putting a giant spacer on top of the coilover, they split it in two and put one in the coil and one on top. Just another way of skinning a cat. Also, I just looked at the article on off-road.com and they complain that the spacers themselves felt and were in fact brittle, but that was in 2005.
    Secondly, Toyota doesn’t approve this. Period. So please don’t spread that for folks that may not do their research and then expect Toyota to cover blown out shocks due to bottoming out. About the only caveat is that they do provide bump stop extensions which seems to be a first for a spacer loft company, but still not revolutionary.
  30. Mar 10, 2018 at 8:46 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    Not upset bro ....just stating that the Revtek is more advanced than the other spacers out there .....And I have had 2 different Toyota dealers tell me it is approved by Toyota...So it is true ....or the 2 dealerships are lying ....anyway , I ain't losing any sleep
