Generic exhaust question
Discussion in 'Performance and Tuning' started by yandeltx, Dec 14, 2022.
  1. Dec 14, 2022 at 3:10 PM
    yandeltx
    yandeltx [OP] New Member
    For those that have messed with exhaust much do you find less drone in a dual in dual out muffler or dual in single out?? For the sake of the question let's say a magnaflow muffler.
  2. Dec 14, 2022 at 3:26 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    @dirtydeeds Keith, can you comment when you have time?
    Thank you..
    @yandeltx I've only had 2 in 1 out mufflers on my 2014.
    I will say the Magnaflow I had had the drone from hell.
    I replaced it with a single-out Dirty Deeds BAM system, it has minimal drone...
    Good luck...
    dirtydeeds likes this.
  3. Dec 15, 2022 at 9:21 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Magnaflow will drone badly. Ive tried them on v8s, 6 and 4cyl and ever time there was drone enough to bring headaches on longer drives.
    Most aftermarket exhausts are generic, not actually tuned for the Tundra configuration, so they typically lose low end torque. And most drone, but that can be subjective.
    @dirtydeeds offerings actually increase HP and torque and you can choose stock quiet or as loud as it can get, depending on muffler length.
    Generally, keeping a single tailpipe works out best for our tundras low end power, unless you are running a supercharger.
    dirtydeeds and 1lowlife like this.
  4. Dec 15, 2022 at 9:47 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    In my experience between my two 2nd gen tundras and a lot of exhausts over the years, when I did dual exits behind the tires I wouldn’t experience as much annoying drone. There may have been small amounts but nothing annoying or super noticeable. This was even with dual SLP loudmouths which are just hollow cans and are quite loud. All of the dual in single exits I had droned, unless I installed one of Keith’s DD resonators on the tailpipe. The only way a single might not drone without a resonator is if you bring it out before the rear tire and eliminate the axle hoop, which I imagine is somehow effecting the frequency of the waves. Not saying this is always going to be the case, just giving my personal experience with a bunch of setups. The worst drone ever was the Carven catback, which the DD resonator was able to cure luckily.
  5. Dec 15, 2022 at 10:19 AM
    These trucks perform better with a single out.
  6. Dec 15, 2022 at 11:57 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Wonder how much "X pipe" fixes the issue with dual.
  7. Dec 15, 2022 at 12:27 PM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I did a muffler swap at first and went with Magnaflow. While I love that brand, it droned like Hell. I switched to what I originally wanted and got the TRD system. No regrets and no drone. It's a true dual system also. I recommend it but Keith over @dirtydeeds is an awesome guy and won't steer you wrong either. With these trucks, you go TRD or Dirty Deeds.
  8. Dec 15, 2022 at 5:59 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    It has nothing to do with drone. Has zero effect.
  9. Dec 15, 2022 at 5:59 PM
    dirtydeeds
    Keith
    USA
    Thanks!!
  10. Dec 15, 2022 at 6:00 PM
    dirtydeeds
    Keith
    USA
    Thanks!!
  11. Dec 15, 2022 at 6:00 PM
    dirtydeeds
    Keith
    USA
    Thanks !!
  12. Dec 15, 2022 at 6:01 PM
    dirtydeeds
    Keith
    USA
    When speaking about a 5.7 with stock exhaust manifolds, this is 110% true!!
    with long tube headers, best power and driveability is had with dual 3” exhaust.
    texasrho83 likes this.
  13. Dec 15, 2022 at 6:02 PM
    dirtydeeds
    Keith
    USA
    thanks!!
  14. Dec 15, 2022 at 6:49 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yessir. Love it everytime I drive it.
    dirtydeeds[QUOTED] likes this.
  15. Dec 15, 2022 at 9:11 PM
    Saltyhero13
    My bust. You're right he wasn't talking about general performance.
  16. Dec 15, 2022 at 11:18 PM
    dirtydeeds
    Keith
    USA
    All good. I’m not the exhaust police. Haha. Just wanted to make sure the OP is informed so he doesn’t waste $$ like so many people do.
    the only way to get rid of drone is to cancel it out. But there’s other things which can help make the canceling effect of a Helmholtz resonator work better. Tube diameter. Muffler type, size, placement, y pipe placement. Etc.
    Creating, or removing drone is a formula. No one thing is the ultimate solution. But a bamuffler is a bunch of tiny solutions which make up a formula that doesn’t drone, doesn’t lose low end torque. And is as loud or as quiet as you want.
