General Supercharger Thread
  1. May 9, 2024 at 6:19 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Not in particular. I use a tweaked version of the TRD VVTI tables, and seen a bunch of other setups from other people.
  2. May 10, 2024 at 10:59 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Finally back from my work trip. Thanks to @TurboKits.com for the awesome fuel regulator. Plenty of room with it on the Whipple. Only redid the fuel line bracket to move the line over. Setting is at stock pressure for now since this thing is super rich and we get time for the retune with @snivilous
  3. May 10, 2024 at 11:21 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Looks good, tons of room with the Whipple...I'm jealous, I've been working on fuel stuff too...I was switching over to the XAT fuel rails while switching over to the Five-0 injectors and running into one issue after another
    The XAT fuel rails have 8AN o-ring to 8AN male end fittings that my vibrant hose end fittings didn't jive with (front 180 fittings interfered with the valve cover and couldn't get them threaded on, rear 45 fitting on passenger side interfered with the wiring harness and also couldn't get it threaded on), so I ordered 8AN o-ring hose end fittings from Racetronix. I finally got everything sorted and made new equal-length lines using PTFE hose, and the rear bolt that holds down the passenger rail barely interferes with the fitting...so now I get to run to ACE hardware to see if they have a button head screw that will give me the clearance I need.
    ZPhilip, Wynnded, HulkSmurf14 and 8 others like this.
  4. May 10, 2024 at 11:29 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea I’m planning on making this same switch keep us posted
    armyoffoo[QUOTED] and Abell207 like this.
  5. May 10, 2024 at 11:45 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Dropped the pressure down to 30. Helped a bit. Mpvi should be here today.
  6. May 10, 2024 at 11:52 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I didn't realize how much room you had with the Whipple to the intake. I knew there was room but wow! Same on drivers? With a competent welder you can have some ports added for extra go juice.
  7. May 10, 2024 at 12:00 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Driver side is a little cluttered just due to the vacuum lines but yes still narrow and clearance for things. Much easier to work on than the 1.9 lol.
    Mdl[QUOTED] likes this.
  8. May 10, 2024 at 12:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Guess I can probably get rid of this RCF throttle body I have lying around lol. Let me know if anyone's interested before I post to the rest of forum. I don't forsee a need to keep it since we're not far off and no issues with the convertor.
    Mdl, Wynnded and Silver17 like this.
  9. May 10, 2024 at 12:28 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    I may be interested in that TB. PM sent
  10. May 10, 2024 at 1:52 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I found some M8x1.25x65mm at ACE, but I have no way to tighten the back one, it allows the fitting to sit closer to where I want it, but still touches...
    I have these screws below coming on Sunday, I should be able to use an allen drive from above to tighten them, and should help with the clearance as well.
    https://www.amazon.com/dp/B01E5CEFJ0
  11. May 10, 2024 at 1:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  12. May 10, 2024 at 1:54 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Dang, I had a touch of agoraphobia there for minute seeing all that open space...
  13. May 10, 2024 at 2:18 PM
    snivilous
    SW UT
    Fuck that, let me introduce you to our Lord and Savior www.McMaster.com
  14. May 10, 2024 at 2:35 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Already checked them out my man, they are my go-to for fasteners if I can't find them locally...but they can't deliver until Monday, and I have to back up and running before then. Hoping Amazon comes through.
    Technically, 3 out of 4 are fully tightened, and the injectors are zip-tied to the rail, so I could probably run it as is. I still need to adjust my feed and return lines from the new Y-blocks and test for leaks though.
    Wynnded, Mdl, e30cabrio and 1 other person like this.
  15. May 10, 2024 at 2:37 PM
    snivilous
    SW UT
    Those fuckers, can't believe they won't deliver on Saturday. :mad:
    e30cabrio, Wynnded and Mdl like this.
  16. May 10, 2024 at 4:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm with you on that front, got the 84mm and a 79mm. Thev GM95mm been running well since November.
    So with the lambda and 103mm unit your shifting and throttle response was normal?
    e30cabrio likes this.
  17. May 10, 2024 at 4:11 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No not normal but not near as bad as I would've thought. Tuning should clear it right up. I thought I wouldn't even be able to parallel park etc just an example on me thinking how far off it'd be. Shifting needs dialing in like you I let off the gas slightly and all is fine
    e30cabrio, Mdl[QUOTED] and armyoffoo like this.
  18. May 10, 2024 at 6:37 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Lol, ya, it would've been a lot easier with more room, in hindsight, removing the supercharger would have been the way to go. I managed to get it tight using a shorty wrench, I had to lift up on the rail and turn the bolt one flat at a time...took for freakin' ever, but it's tight. All 4 bolts are tightened and the lines are attached and tightened up to the y-blocks, so that should be the hard part out of the way.
  19. May 10, 2024 at 7:21 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    You’ll have to send me a parts list
    Mdl, e30cabrio and armyoffoo[QUOTED] like this.
  20. May 10, 2024 at 7:55 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    XAT Fuel Rails
    2 x Racetronix FIT-P8R1808, 2 x Vibrant VPE2808 for front of rails to y-blocks
    2 x Racetronix FIT-P845R8, 2 x Vibrant VPE2808 for rear of rails to y-blocks
    2 x Vibrant VPE-28908, 2 x Vibrant VPE2808 for top of y-blocks to FPR and Filter
    2 x Aeromotive 15674 y-blocks
    1 x PTFE Fuel Line Vibrant Performance 18978
    1 x M8 x 1.25 x 65mm button head cap screw for rear passenger mount
    rear of rails to y-block is 7" each side, front of rails runs parallel with rails and rear lines, and ends at y-block at same level/distance as the other y-block
    Silver17, Abell207, Mdl and 2 others like this.
  21. May 10, 2024 at 8:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Awesome added it to the list thanks!
    Mdl and armyoffoo[QUOTED] like this.
  22. May 10, 2024 at 8:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Getting ready to install a engine oil temp gauge at filter. Curious if anyone has any temp ranges. I'll do a couple hard runs and see where it's at. Wanted to see where its at before installing an engine oil cooler.
    I do have an e-fan instead of the mechanical one. Not sure if it makes any difference but engine temps have always been normal.
    pursuit2550, Abell207 and reywcms like this.
  23. May 11, 2024 at 4:22 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    How do those XAT fuel rails compare to the Prospeed ones?
  24. May 11, 2024 at 5:36 AM
    pursuit2550
    pursuit2550 New Member
    Only temp reading I have gotten are from my OBD MX app. From what I have read, we dont have a temp oil sensor, so a calculation is used to show oil temp. To me it's useless. I have trans temp, trans T/C temp, engine temp and oil temp. The oil temp was always the same as the engine temp. They actually went up and down the same degrees and was no more than 1-2* difference. Trans temp is usually around 190* or below and engine temp 195 up to 203. Yesterday it was 100* here. Engine got to 203*, trans 191*, IAT got to 152* stuck in traffic, backed down to 10*+/- above ambient once I got on the highway.
    NatesNightMare and Mdl[QUOTED] like this.
  25. May 11, 2024 at 6:03 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    In your face domestic trucks! Tundra has the biggest dick!
  26. May 11, 2024 at 8:32 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The XAT rails are 8AN vs ProSpeed's 6AN, although I think you can swap fittings to make ProSpeed 8AN I don't believe the rail is large enough. Don't quote me on that though, as I haven't opened mine up...yet. I also like the design of the XAT, that it has the injector tab positioning that the stock had, and it doesn't have PROSPEED stamped all over it.
    I've been having issues with AFR differences between my banks, so swapping injectors was going to be my next course of troubleshooting, but I already had cleaned/tested injectors ready to install and the XAT rails, so I decided to make my feed/return lines equal length at the same time and reduce any variables in my control. I also have a tendency to over-complicate things, so don't take anything I do as necessity for supercharging your truck.
    Now that I've swapped rails and engine bay lines, my ProSpeed fuel system (minus pump) will be up for sale soon, so I can recoup enough money for like 3 or 4 of the fittings I bought :rofl:
    Black@Blue19, Mdl, Wynnded and 2 others like this.
  27. May 11, 2024 at 8:42 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    PSB-1 ordered…..Tacoma/Tundra vent mount acquired. Now just have to play the waiting game on delivery!
    HulkSmurf14 likes this.
  28. May 11, 2024 at 9:28 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Haha I am hopefully installing mine today. The vent mount / removing the vent was straight forward and looks clean. Now I'm trying to find the best way to power it. My first attempt will be the rear window button, which my model doesn’t have but the button harness is present, looks like there is a constant 12v available.
  29. May 11, 2024 at 9:38 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    There should be empty fuse slots in the box under the dash that are key-on. You can just stick an add-a-fuse in there. You don't want constant 12v for the gauge
    Fastlane47 and Mdl like this.
  30. May 11, 2024 at 9:59 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Thank you sir. Do you know roughly where they are? I was looking under the left hand driver side this morning.
    This is an add a fuse right?
