Generac generator opinion
Discussion in 'Home Improvement' started by NoMoTaco, Jun 4, 2019.
  1. Jun 4, 2019 at 3:34 PM
    NoMoTaco
    NoMoTaco [OP] New Member
    Bluffton SC
    2018 Tundra DC TRD OR Silver
  2. Jun 4, 2019 at 4:13 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Humm,
    I didn't see what the RPM is on the literature
    I know on light-medium commercial units, Generac will up the RPM to accommodate for a small engine and gear it for the proper alternator RPM.
    This will give the engine less life and louder DB.
    NoMoTaco[OP] likes this.
  3. Jun 4, 2019 at 4:37 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Seems generac RPM is high in relation to the kohler
  4. Jun 4, 2019 at 4:51 PM
    P-Factor
    P-Factor New Member
    In order to produce 60 Hz (cycles), all generator engines must operate (run) in multiples of 1800 rpm's, i.e. 1800, 3600, 5400, etc.
    TomC843, Sas, ColoradoTJ and 2 others like this.
  5. Jun 4, 2019 at 4:58 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    On a 2 pole alternator 3600RPM is required, On a 4 pole alternator 1800 RPM for 60hz
    An engine can always be geared for proper alternator speed.
  6. Jun 4, 2019 at 5:07 PM
    P-Factor
    P-Factor New Member
    Correct!
    NoMoTaco[OP] and OBXTundra like this.
  7. Jun 5, 2019 at 5:55 AM
    NoMoTaco
    Bluffton SC
    Standby models are not a consideration.
    Will wire these units in via interlock switch. Run most of house depending on time of year, needs etc.
    Basically the model i posted is a tweener. Better built and more features than the GP line but doesn’t have the OHVI engine or $$ cost of the XG line.
    Getting my mind past the no OHVI engine and oil filter, I think these should do intended job with proper continued maintenance.
    Is there another brand or model that I should look at?? Any experience or suggestions? Thx for above replies!!
  8. Jun 5, 2019 at 6:13 AM
    Thats a pretty good deal on that generator.
  9. Jun 5, 2019 at 6:33 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    We personally have a generac 22kw hooked up to our house. we ran a delay on one of our ac units so it's not trying to power up both at the same time. we have a 500 gallon propane tank we buried when we built the house. It does a test run for 5 minutes every other saturday morning. it has done us well the couple times it's had to be utilized. our neighbor behind us has one too as well as 2 3-ton units and ours can run our whole house no problem for a couple days. i'm happy with it so far
    NewImprovedRon likes this.
  10. Jun 5, 2019 at 9:43 AM
    NoMoTaco
    Bluffton SC
    Agreed!
    Ok. Ordering two units today.
    Copper not aluminum windings sealed deal.
    (As per generac CS)
    EFI (get a DAP tune?? Lol)
    <5% THD
    9.5-10 hrs per tank
    Low oil shutoff
    Idle control (manual)
    Outlet covers.
    Electric and pull start.
    Thanks for feedback. Sort of thinking out loud here and very helpful.
    -NoMoTaco
    NewImprovedRon, Trooper2 and Fotnot like this.
  11. Jun 7, 2019 at 9:16 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I see you already ordered but an FYI if any one else is looking Champion 7500 watt dual fuel units are on sale at Tractor Supply for 699 this week. Saw it in the ad today can't find it online yet.
  12. Jun 7, 2019 at 10:25 AM
    NoMoTaco
    Bluffton SC
    Called Tractor supply. $849
    They said it may have been last weekend
    FYI
  13. Jun 7, 2019 at 10:58 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Interesting, the ad just came in the mail today. I'm out but I'll investigate further when I get home.
  14. Jun 7, 2019 at 11:22 AM
    NoMoTaco
    Bluffton SC
    Awesome!
  15. Jun 7, 2019 at 11:22 AM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    I know you have ordered already, this is mainly a huge vote for dual fuel. This is my set up I bought about 4 years ago after being stuck in an ice storm without power for 4 days because "country living". I have spent the last 4 years watching Craiglist, local sales, and my local dump drop off for cheap / free old LP tanks, take to Wal-mart to exchange for new full for $14.88. I have almost 20 put away. Not one drop of gasoline has ever been in the gen, I have gone 9 months and it always starts because only LP has ever been in it, BUT if I ever need it I have the option. Mine came from Costco, $799ish.
    PS- have used for 2.5 days straight, no troubles.
    Trooper2 likes this.
  16. Jun 7, 2019 at 11:28 AM
    TomC843
    Tom
    Charleston, SC
    Here she is.
  17. Jun 7, 2019 at 11:34 AM
    War Machine
    War Machine SSEM # 5 3MW
    @NoMoTaco
    It looks like I’m a little late, but I sell Generac, and can check pricing on Generac products. It’s generally not cost effective for me to sell and ship one, but I can certainly advise on pricing. I’ll say there’s generally very little mark up in them.
  18. Jun 7, 2019 at 11:45 AM
    War Machine
    I just checked. It’s an incredible deal on it. Even at $999.00 it was a hell of a bargain.
  19. Jun 7, 2019 at 12:54 PM
    NoMoTaco
    Bluffton SC
    I thought so but...
    Pressure washers, sprayers, hvlp’s, festool Sanders etc I know. Lol generators not so much.
    One is for me as I’m in process of moving to South Carolina. The other I’m building a shed and dropping an interlock at 91 yr old moms in Connecticut. (Friends will pop by and make sure it’s running when needed)
    The Champion was intriguing but this model Generac was better fit as no propane is on her property.
    Thanks everyone for input!!!
  20. Jun 7, 2019 at 1:01 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    How long does one tank last?
  21. Jun 7, 2019 at 1:30 PM
    TomC843
    Tom
    Charleston, SC
    8 hours ish, depending on how hard it is pulling.
    Trooper2[QUOTED] likes this.
  22. Jun 7, 2019 at 1:48 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I have one of these, only complaint is the thing is loud.
    Use it for the same purpose, backup to my house power in the event of sustained power outage.
    runs great on propane and gas, its a little slow to start when switching between the two fuel types.
  23. Jun 7, 2019 at 2:57 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
  24. Jun 7, 2019 at 2:57 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Here it is, valid June 12-16
  25. Jun 7, 2019 at 3:59 PM
    NoMoTaco
    Bluffton SC
    Hmmmmmmmmmmm
    Hmmmmmm
  26. Jun 7, 2019 at 4:01 PM
    NoMoTaco
    Bluffton SC
  27. Jun 15, 2019 at 3:01 PM
    NoMoTaco
    Bluffton SC
    This sale is live till end of Father’s Day
    Nice snag
