Gen3 Build.
Discussion in '3rd Gen Tundras (2022+)' started by GiddensGen13, May 11, 2023.
  1. May 11, 2023 at 9:16 AM
    GiddensGen13
    GiddensGen13 [OP] New Member
    Cale
    Gen1 2001 sr5 4x4 gen3 1794 4x4
    Many
    I got this truck last week and took it to the trim shop for tires, tint, level, and step bars. I haven’t picked it up yet but I was pretty tickled with the looks. Running 37x12.50 super swamper SSR, westcott tire clearance kit, readylift 3” stt, gorhino e steps. Can’t wait to pick it up.
    rozemab, Yaboy, mayan and 3 others like this.
  2. May 11, 2023 at 10:04 AM
    jhtram
    jhtram If I'm curt with you it's because time is a factor
    Jay
    Raleigh, NC
    2023 Lunar Rock Tundra Limited TRD
    OEM TRD Lift Maxxis RAZR AT LT285/65R20 tyres Spidertrax 1" Spacers Retrax Pro XR Tonneau Bumpershellz 'stache overlay TRD Pro Fender Flares Yakima Overhaul HD Bed Rack OEM Blackout Overlays aFe Front Tow Hooks Talon's Cat Shield Undercover SwingCase Toolboxes TufSkinz Console Cover (Matte black) ScreenProtech LCD and instrument cluster protectors Tailgate & bumper vinyl inserts (texas decal king)
    Looks great! How much modification was needed to eliminate rub on those tires?
  3. May 11, 2023 at 11:34 AM
    GiddensGen13
    Cale
    Many
    That westcott tire clearance kit handled that.
  4. May 11, 2023 at 12:15 PM
    gearnuts
    gearnuts New Member
    Joel
    Greer, SC, United States
    good looking truck! i haven't heard of westcott tire clearance kit, seems like the readylift and westcott are similar items. interested in the details
  5. May 11, 2023 at 1:12 PM
    GiddensGen13
    Cale
    Many
    I looked at their lift and talked to both people. I’ve had several readylifts in the past and decided to go with their lift bc it replaces the upper control arms.
    The tire clearance kit has a couple of brackets you mount to the frame and some plastic stock style rivets to pull the fender liners back. It also has the body mount relocate stuff where you cut those blocks off of the frame and weld in a cover plate.
    the installation of the ready lift requires you to unplug the ECM. After disconnecting the battery cables, unplugging and unbolting the ecm, and installing the lift and then reconnecting cables in reverse order, the truck is now throwing numerous codes including limited power etc. Waiting to hear back from the dealership on the next step is why I haven’t picked the truck up. Readylift is telling us it shouldn’t have done that.
    gearnuts[QUOTED] likes this.
  6. May 12, 2023 at 7:40 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Damn good looking truck. Hope you get the issues worked out quickly.
  7. May 13, 2023 at 1:20 AM
    GiddensGen13
    Cale
    Many
    thanks! All of the codes turned out to be associated with the alignment and wheel position sensors etc. after alignment was done all is well.
    4genRunner[QUOTED] likes this.
