Gen1 alloy wheel ctr dust caps recommendation?
Discussion in '1st Gen Tundras (2000-2006)' started by ps8820, Jun 6, 2024.
  1. Jun 6, 2024 at 10:55 AM
    ps8820
    ps8820 [OP] New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    New to me 06 AC w/5 [slotted]20240601_093753(1).jpg spoke 17"x6 alloy wheels, but hub dust caps gone.
    So, are the Toyo originals that much better than the aftermarkets on Ebay, hubcapheaven, etc?
    It looks like the Toy oem are also plastic, but maybe better quality?
    From near $75 to 100 each for Toyo, or as little as 25-30 for knock-off set of four...
    Big difference!
    Advice/comments please. Thx, ps.
  2. Jun 6, 2024 at 11:09 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Bought my Tundra in 2017, missing 2 of the 4 center caps. Bought generics off Amazon. Side by side I could tell they were somewhat inferior quality to OEM, however once I replaced all 4 you'd never know they weren't original without an OEM cap to compare to. Kept them for 6 years before getting new wheels and they still looked perfect. Would buy them again 100% if I needed to. This pic was 3 years after putting them on.
  3. Jun 6, 2024 at 12:01 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I agree with @Mustanley However, mine did not last so long
    you get 4 for a fraction of the cost of one OEM so even if it doesn't last as long as his, you would have spares
  4. Jun 6, 2024 at 4:04 PM
    ps8820
    joe
    interesting..may look into buying 2 sets of aftermarket.
    Seems like theyd get 'brittle' over time and 1st tire changer throws it on a tire-dismounter, cap probly disintegrates, whether Toyo or aftrmrkt.
    Weagle likes this.
  5. Jun 6, 2024 at 5:19 PM
    Weagle
    Prattville, AL
    Mine may not be the same ones as @Mustanley but the plastic itself was OK. It was just the Toyota emblem Was stuck on with some black adhesive
    from a distance You probably wouldn't know.
    The centerpieces themselves lasted fine, but one or two of them lost their fake Toyota emblem and I just rubbed the black adhesive off until I eventually replaced it
