Gen 3 wheel insights.....
Discussion in '3rd Gen Tundras (2022+)' started by mountaingroan, Jan 12, 2022.
  1. Jan 12, 2022 at 3:32 PM
    mountaingroan
    mountaingroan [OP] New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    So I have a '22 on order.
    I'd like to use my old Gen 1 steelies and winter tires/studs on the new whip for Winter use. The tires are virtually new. A source here mentioned that the 16"er's might not clear the Gen 3 caliper/rotor/shield etc.
    Has anyone tried to put a 16" Gen 1 Tundra or Taco rim on a new '22?
    Thx in advance...
  2. Jan 12, 2022 at 3:41 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    If the rotors and breaks carry over from the 2nd gen then if I am not mistaken the smallest wheel you can run is a 17”.
  3. Jan 12, 2022 at 4:04 PM
    Taco-Spike
    Two Trucks
    Are the gen 1 6 lug?
  4. Jan 12, 2022 at 4:43 PM
    randomquickness
    randomquickness New Member
    17's are a tight fit so I'm doubting 16' will clear the brakes
  5. Jan 12, 2022 at 5:28 PM
    mountaingroan
    North Idaho
    Yep...seems like consensus is that 17's work--tight, the 16s do not.
    Taco-Spike[QUOTED] likes this.
  6. Jan 12, 2022 at 5:30 PM
    Yes. 6 on 5.5”. Same lug pattern as Tacoma’s and 4RUNNER’s. The offsets are different between models but generally interchangeable.
  7. Jan 12, 2022 at 5:49 PM
    Taco-Spike
    Two Trucks
    good to know!
  8. Jan 12, 2022 at 6:37 PM
    mountaingroan
    North Idaho
    Yep, thanks guys. Appreciate the input!
