Gen 3 Tundra with AVS/Air
Discussion in '3rd Gen Tundras (2022+)' started by Dave22, Aug 4, 2022.
  1. Aug 4, 2022 at 5:42 AM
    Dave22
    Dave22 [OP] New Member
    Has anyone here noticed a height difference within the rear end? My driver side rear end sits 1/2 lower than my passenger side rear end. I measured from the ground to the frame and from the ground to the rear fender flares both reading the same difference. Also measured the rear tires to make sure and they were both the same size. Any inputs would be appreciated.
  2. Aug 4, 2022 at 6:08 AM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
  3. Aug 4, 2022 at 6:14 AM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    Before you adjust it, did you measure with a full and empty tank? Or with and without a driver? 192 lbs with a full vs empty tank, and approximately the same weight for a driver, can make a difference. A full tank with a driver should cancel out since they're on opposite sides of the frame. I'd measure it either with an empty tank and no driver or full tank with a driver.
    And, honestly, a half inch is within the margin of error. You'll be chasing that to no end.
  4. Aug 4, 2022 at 6:42 AM
    Dave22
    Thanks! I measured with a full tank and no driver. The right side is running 1/2 higher than the left with a full tank and no driver so I would think with an empty tank that number would be greater, correct.
  5. Aug 4, 2022 at 12:13 PM
    Demar002
    Demar002 New Member
    2022 Toyota Tundra
    It has been well documented. The levers were off from side to side upon delivery. I can speak from experience that was indeed the case, I leveled them. They were still off from one side to another but it was an 1/8 of an inch. Well within specs
