Gen 3 Park Assist issue
Discussion in 'General Tundra Discussion' started by casher2006, Apr 7, 2020.
  1. Apr 7, 2020 at 12:43 PM
    casher2006
    casher2006 [OP] New Member
    2016 Toyota Tundra Double Cab w/6" Lift
    I just purchased a 2016 Tundra SR5 with a 6 inch lift and the dealer told me to keep the Park Assist off because they wont work since the truck is lifted. I asked them if the Sonars could just be re-calibrated and they said no.Anyone know if this is true or is the dealer just being lazy since the repair/re-calibration would be free with my extended warranty???
  2. Apr 7, 2020 at 12:53 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    I sit about 3 inches + tire size difference higher than you (8.5 lift on 38s) and my parking sensors still work fine. Thats probably your dealers way of covering his own ass so he can say he warned you.
  3. Apr 7, 2020 at 12:56 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Exactly, I don't understand why the system wouldn't work with a lift. The only thing I would think the sensors a seeing things a little higher. You might run over things that are below the sensors reach.
  4. Apr 7, 2020 at 12:58 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    if its small enough to be below my sensor I was planning on running it over anyway lol
    bleach likes this.
  5. Apr 7, 2020 at 1:05 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Hes just covering is ass. They sensors will still work. Mine work with a 7” lift. But they wont see things that are too low
  6. Apr 8, 2020 at 12:15 PM
    casher2006
    Thanks everyone
  7. Apr 8, 2020 at 12:23 PM
    TTund16
    TTund16 New Member
    lol
    :mudding:
  8. Apr 8, 2020 at 12:31 PM
    TTund16
    TTund16 New Member
    The sensors in mine don't seem to be that sensitive. You have to get pretty close to an object for them to beep. Front needs an angle to it also. meaning you have to be turning into things to beep.
    I think the extra 6" lift, makes it even less sensitive for smaller or shorter objects below the fender level.
    Can you adjust the sensitivity or the warning distance by calibration? What's the process like?
  9. Jul 19, 2020 at 7:46 PM
    TRDpro4x4
    TRDpro4x4 New Member
    2016 TRD DC 5.7V8
    I just bought one privately a month ago, 3 of the sensors dont work..it seem they are short lived. I am glad the camera works which is all i need.
