Gen 3 Failures
Discussion in '3rd Gen Tundras (2022+)' started by txk131, May 12, 2024.
Thread Status:
Not open for further replies.
  1. May 12, 2024 at 2:43 PM
    txk131
    txk131 [OP] New Member
    2024 Tundra SR5 - 2001 Sequoia SR5
    Is all the negative talk on here and YouTube about the gen 3 Tundra and spun bearings warranted? I bought this truck in a rush without much research and thought I was making a good choice based of the gen 1/2’s reputation. I intended this truck to be kept long term but after hearing about all the failures I’m in a panic with buyer’s remorse.
  2. May 12, 2024 at 2:54 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I feel the same way but I am waiting to hear more about what is really happening with these failures.
    However, consider that if 300,000 Tundras have been sold and we have heard of maybe 50 to 100 failures. There are probably more that we don't hear about but even if there were say 300 to 1,000 failures, That doesn't represent a huge pool of trucks.
    And that the tracking seemed to indicate that most of these occurred on trucks built before March 2023. Maybe only a couple have failed with newer build dates.
    My concern has been calmed by this reality. If the engines were failing all over the place, we see something from Toyota addressing the issue.
    As far as warranty goes, i believe that all the failures have been covered with the exception of maybe the first or second one.
    ChucklesToy and txk131[OP] like this.
  3. May 12, 2024 at 2:58 PM
    If your bearings sh!t the bed, then it was all warranted. If you have years of trouble free enjoyment like most will, then it’s all just the ramblings of the few that suffered a failure. I wouldn’t worry about it personally. Just enjoy your truck.
  4. May 12, 2024 at 7:10 PM
    txk131
    Is there any solid evidence to what is causing the bearings to fail? One interesting theory I have heard is fuel quality and octane rating. Meaning, regular 87 octane causing pre-ignition knocking and thus damaging crankshaft bearings.
    In Fords 3.5l eco boost owner’s manual, they specifically state that higher octane will improve performance. It also mentions that light knocking could still happen with the recommended 87 octane.
    Toyota’s manual doesn’t get specific and only states that 87 or higher should be used. Could the fix to this bearing issue be as simple, but expensive, as using higher octane fuel.
  5. May 12, 2024 at 7:13 PM
    Breathing Borla
    Northern Illinois
    Why worry about something that has not happened yet nor is very likely to happen
    boost on and enjoy your truck
  6. May 12, 2024 at 8:11 PM
    smileytn1
    smileytn1 New Member
    I always run marvel mystery oil in tank pretty cheap turbo and fuel pump protection and 87 octane or 89 whatever your budget the computer will mix the rest. Try 102 av fuel you can get a chance at blowing a piston and turbo.
  7. May 12, 2024 at 10:31 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    V8 will always be waiting for you when you decide to come back.
  8. May 13, 2024 at 5:06 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Saw an article about a 3rd Gen that went thru 3 engines.. :eek2:
  9. May 13, 2024 at 5:10 AM
    Tremor F-250, Roush Mustang, Jeep Crawler
    We don't need yet another thread on 3rd Gen motor failures.
Thread Status:
