Gen 1 Tundra Bench VS Bucket Front Seat
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Apr 12, 2021.
  1. Apr 12, 2021 at 9:13 AM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Hi everyone, I recently purchased a 2004 Tundra DC that came with cloth bucket seats and center console. I'd like to swap this out with a front bench seat, so I'm looking for someone in the PNW (preferably close to Seattle but I can travel for the right one) who is looking to swap seats the other way.
    That being said, I see most people swapping their bench seats out and replacing them with bucket seat + center console. What are the pros and cons of each setup? In my mind the bench seat is better because it adds movement space across the width of the truck's front seat. Are the cons just the loss of center console? Are the bucket seats wider than the individual driver/passenger seats from the bench setup?
    Adventundra, theblurry1 and Darkness like this.
  2. Apr 12, 2021 at 9:19 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think the bench seats are a bit wider if anything (with the arm rest down). The bu kits taper inward as they move toward the backrest but the bench seats don't do that.
    The con might be that with the bench setup you can't really put anything on the trans hump. Stuff slides off too easily so it makes real estate of your cup holders valuable. I do like having the bench but at some point I want to swap to aftermarket seats and likely find an oem console. I'm too far away and wrong color to trade you though.
    DarkMint[OP] likes this.
  3. Apr 12, 2021 at 9:43 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Setting aside pros/cons which definitely count, I would look at it along the angle of what’s best for you and perhaps family. For me personally, I’m an ole retired fart and it suits me perfect since it’s just me riding in it and we use wifes Highlander for traveling. When we do use it, the wife loves it....very comfortable !
  4. Apr 12, 2021 at 10:27 AM
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    If you were in chicago id trade you i have the right color and everything
  5. Apr 17, 2021 at 8:31 PM
    PGP03
    PGP03 New Member
    2003 Grey Tundra
    I might be interested. Located in Bellingham. Does everything switch right over?
  6. Apr 17, 2021 at 8:37 PM
    PGP03
    PGP03 New Member
    2003 Grey Tundra
  7. Apr 19, 2021 at 4:32 AM
    eddieb02
    eddieb02 New Member
    Eddie
    2005 tundra sr5
    Stock for now
    Hi, not to have my very first post be a hyjacked thread but I am in New York and actually interested in swapping my bucket seating for bench as well. Can send pics shortly, it’s black center console
  8. Apr 19, 2021 at 5:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I like the bench cause you can just shove your pistol under the arm rest. Easy access.
  9. Apr 19, 2021 at 5:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Same here. And it's completely out of sight. Also, the arm rest on the buckets looks hard, and not as comfy as the soft one that come with the bucket. I still have 4 cupholders too which is plenty.
    Schcoman likes this.
  10. Apr 20, 2021 at 7:50 PM
    ChrisR66
    ChrisR66 New Member
    2004 Gold AC Tundra
    I'd like to swap out my buckets for a bench in my '04 AC SR5 as well. I always found benches to be more comfortable going back to my first vehicle, '67 Malibu. Anyway, I'm thinking of a solid bench like in a regular cab, not sure if it is possible especially w/ a manual trans. Does anyone know if I could pull this off?
  11. Apr 20, 2021 at 8:05 PM
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
    Man I want to swap my bench for buckets as well. Has anyone that has done this have any tips in terms of where you might find it, junk yards?
    Sorry to hijack and if you were closer I would drive right over
  12. Apr 20, 2021 at 11:24 PM
    DarkMint
    Ben
    I think they switch over mostly fine, but I might need another piece to make it work. Yours should be fine to just bolt in a bucket seat. From what I've read on this forum, the Tundras that come with bench seats have longer seat rails on the floor which can accommodate bucket seats. But factory bucket seat Tundras have slightly shorter seat floor rails that will need a DIY extender to make bench seats swap in.
    If possible can you post a pic of the bench seat arm rests?
    Also, after I created this thread I discovered that the bucket seat center console cup holders can actually fit my wide NALGENE water bottle. Which is a total mindfuck since no other car I've found has been able to fit one. That alone gives me pause on swapping.
    Any chance you or someone else knows if the bench seat cup holders can fit Nalgene water bottles?
    thunder100 and theblurry1 like this.
  13. Dec 8, 2021 at 7:21 PM
    Kilgore Trout
    Kilgore Trout New Member
    Oregon
    2002 AC Toyota Tundra SR5 4.7L V8
    Airaid Cold Air Intake, Magnaflow Dual Catback Exhaust, 2017 18” 4Runner Wheels
    I have an 02 SR5 with bench seats. Interior is gray. I’d be interested if you don’t mind gray. I’m located in Portland.
  14. Dec 8, 2021 at 7:40 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    the pic he posted is the armrest.
    Its a center seat when up, and a center armrest for two when down, the padding lifts for storage, Mine does not fit a traditional 1L nalgene.
  15. Dec 9, 2021 at 6:22 AM
    DarkMint
    Ben
    There's the answer I needed and ultimately a deal breaker. It's a shame since a bench seat would be great, but I need muh truck to fit muh nalgene...
  16. Dec 9, 2021 at 6:31 AM
    10 blue trucks
    04 4WD RCLB
  17. Dec 9, 2021 at 10:05 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Wonder if you found an 05 or 06 bench if that would work. The cup holder on the right side is bigger than the left of the armrest on mine, which is different from the 00-04s. Happen to know the exact diameter of your Nalgene bottle?
  18. Dec 9, 2021 at 10:20 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  19. Dec 30, 2021 at 1:49 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    Anyone done this swap in a DC? How do the cupholders compare?
  20. Dec 30, 2021 at 7:47 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Sex is easier using bench seats over buckets.
  21. Dec 30, 2021 at 8:48 PM
    DarkMint
    Ben
    Nalgene bottle diameter is 3.5"!
  22. Dec 30, 2021 at 8:48 PM
    DarkMint
    Ben
    Damn son.
  23. Jan 1, 2022 at 6:19 AM
    EvilMilkshake
    05 AC Limited 4x4
    Totally would fit!
    DarkMint[QUOTED][OP] likes this.
  24. Jan 1, 2022 at 8:11 AM
    DarkMint
    Ben
    Aw snap!!! Look at that, beautiful. Never been so happy about 3.5 inches before.
    Now in the time I've gotten the truck, the wife has become used to having the center console. I think I need to reopen the conversation.
    bmf4069, nickrick78 and FirstGenVol like this.
  25. Jan 1, 2022 at 8:19 AM
    EvilMilkshake
    05 AC Limited 4x4
    Good luck!
    Reminder -- this is for a 2005 AC bench seat. They are different than the prior years, but I think the 2006 are the same.
  26. Jan 1, 2022 at 9:44 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I like my bench seat! It's old school and I can store a lot of stuff in the armrest.
  27. Jan 1, 2022 at 10:30 AM
    DarkMint
    Ben
    Nice. Pictures like this are just proof to help me convince the wife.
    I like the multi tool. Nice Spyderco! Also, is that a stun gun?
    FirstGenVol[QUOTED] likes this.
  28. Jan 1, 2022 at 10:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No it's actually a tire pressure gauge but now that you mention it I can see how it would like like a stun gun.
  29. Jan 1, 2022 at 10:35 AM
    Outbound
    Aaron
    Northern Alberta
    I'll never own a truck without bucket seats and a full center console again. They're way more comfortable to me and the console is way more functional.
    snoope and shifty` like this.
  30. Jan 4, 2022 at 8:28 PM
    TBinky
    TBinky Wassup weirdos
    2000 black tundra
    Hey is that a spyderco tenacious?
    I work at lynch northwest and we make custom clips for those
