Gen 1 '02 Tundra. transmission fluid
Discussion in '1st Gen Tundras (2000-2006)' started by Paulbunt, Jan 6, 2024.
  1. Jan 6, 2024 at 6:31 PM
    Paulbunt
    Paulbunt [OP] New Member
    paul
    2002 tundra SR5
    none
    2002 Trunda, 225K miles. my transmission fluid is going down. I don't see any visible leaks, and the fluid is clean, no water. old vehicles had a vacuum modulator that would go bad and suck fluid. do they still use them?
  2. Jan 6, 2024 at 8:36 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    check that your coolant isn't being contaminated and increasing in volume. The transmission oil cooler (lower two barbs on bottom tank of radiator) is know to fail and leak into the cooling system.
  3. Jan 7, 2024 at 2:55 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This ^^^
  4. Jan 8, 2024 at 8:29 AM
    Paulbunt
    paul
    2002 tundra SR5
    none
    my water is clear and red in color. i don't remember seeing red antifreeze. transmission fluid is red and clear. does it get milky when mixed like oil and water or can it remain clear?
  5. Jan 8, 2024 at 9:13 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Toyota correct coolant is either pink or red
    Toyota ATF for 2000-2002 is Dexron-III which is red
    When oils mix with water it forms an emulsion which looks like milkshake
  6. Jan 8, 2024 at 9:17 AM
    Paulbunt
    paul
    2002 tundra SR5
    none
    thanks water and ATF are not mixing but my ATF is going down and i can not find a leak.
  7. Jan 8, 2024 at 9:32 AM
    shifty` Animals and insects don't do drugs
    When you say the trans fluid level is going down, I just need to sanity check here for a sec. The levels are quite different at operating temp vs. cold. When you're measuring, can you just confirm it's always been measured while hot, or always while cold?
    tvpierce and FrenchToasty like this.
