Gearing up to build a street sleeper.
Discussion in '2nd Gen Tundras (2007-2013)' started by CrewMaxZZ, May 28, 2015.
  1. May 28, 2015 at 7:19 PM
    CrewMaxZZ
    CrewMaxZZ [OP] New Member
    Jémich
    2008 BlackMax
    Dual exhaust Magna flow Y pipe. Oem airbox mod k & n filter
    Hey whats happenin? Im new on the forum & appreciate the acceptance. I got a bunch of questions coming up. Im am about to install a Trd supercharger in my 2007 Sr5 Crew max. Suspension is a must. Suggestions or experience welcome. Also I was thinkin jba Long tube headers since they are the closet to the oem symmetry to attach to my dual in dual out mag flow exhaust. Any advice for transmiision gearing as well?
  2. May 28, 2015 at 7:30 PM
    Welcome and :popcorn: for build on this!
  3. May 28, 2015 at 7:32 PM
    CrewMaxZZ
    Jémich
    2008 BlackMax
    Translate for me
  4. May 28, 2015 at 7:34 PM
    Which part? I was saying I'm excited to see this! I dont have any personal experience on the specific questions you mentioned, but several here do...and we can help you research.
    CrewMaxZZ[QUOTED][OP] likes this.
  5. May 28, 2015 at 7:35 PM
    Mike Tread lightly.
    south carolina
    Not much chillaxin...
    Supercharger with unichip piggy back. Load the super charger config alittle ( fine tunning on dnyo) . Run the trd headers not jba I have them in my Tacoma they are ok. Trd exhaust or borla or corsa to hide the s/c. Get rid of the silencer. If you want to go wild let me know.
    Transmission you need to know final gearing in the transmission.
  6. May 28, 2015 at 7:37 PM
    I wonder if he were to run 4.88 if that would help? Are you keeping the stock tire size, OP?
  7. May 28, 2015 at 7:42 PM
    CrewMaxZZ
    Jémich
    2008 BlackMax
    Tires def will change but trying to stay low key. Mike you got jbs in the tacoma? Good to know didnt look into the trd headers yet thx...
  8. May 28, 2015 at 7:43 PM
    CrewMaxZZ
    Jémich
    2008 BlackMax
    Silencer on the oem fwd or aft bnks 1 or bnks 2?
  9. May 28, 2015 at 7:44 PM
    Mike Tread lightly.
    south carolina
    Jba are ok if I had to do it over I would have went with doug headers.
    Wynnded likes this.
  10. May 28, 2015 at 7:44 PM
    Mike Tread lightly.
    south carolina
    Fyi. My 03 will be a sleeper soon.
    T-Rex266 and CrewMaxZZ[OP] like this.
  11. May 28, 2015 at 7:45 PM
    CrewMaxZZ
    Jémich
    2008 BlackMax
    Oh popcorn..like waitin for it to start..ahhh..long day..lil slow
    T-Rex266[QUOTED] likes this.
  12. May 28, 2015 at 7:46 PM
    CrewMaxZZ
    Jémich
    2008 BlackMax
    I have been checkin those dh's out..the price point on Amazon is competitive too. 567.00 otd
  13. May 28, 2015 at 7:47 PM
    Mike Tread lightly.
    south carolina
    2nd ones.
  14. May 28, 2015 at 7:49 PM
    Mike Tread lightly.
    south carolina
    I bought my jba as I was going to supercharge my tacoma but do to other things going on its on the back burner for a few years.
  15. May 28, 2015 at 8:05 PM
    Mike Tread lightly.
    south carolina
    Sean he will need to change his final gear in the transmission too. If he wants to kick it up a notch you have to regear all gears and boost hydraulic pressure.
  16. May 28, 2015 at 8:22 PM
    CrewMaxZZ
    Jémich
    2008 BlackMax
    Can DIY the o2 sensor then or do I have to re weld a port for a reading still so I dont get a chk eng lite?
  17. May 28, 2015 at 8:26 PM
    Mike Tread lightly.
    south carolina
  18. May 28, 2015 at 8:47 PM
    CrewMaxZZ
    Jémich
    2008 BlackMax
  19. May 28, 2015 at 9:53 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome! I have always wanted a sleeper truck. Get laughed at when you think you can hang with their Honda Civic with large pointless rear spoiler and ground affects. Then the tree drops to green and you launch way ahead for the win. Wouldn't need a supercharger against a civic but you get my point.
    SC'ing is expensive. SC, install kit, programmer, pulley, intake, headers, O2 sensor delete, exhaust, transmission gearing, differential gearing, brakes and dyno time.
    Could also do intercooler, injectors, Pistons, Rods, Valves, Springs, Performance Camshaft, machining, rings, gaskets ........
    Cant wait to see your build up though.
    Ianspei and CrewMaxZZ[OP] like this.
  20. Jun 4, 2015 at 1:20 AM
    Ianspei
    Ianspei New Member
    Ian
    Huntsville, Ontario Canada
    2013 White Platinum Crewmax Tundra
    Levelling kit front and rear, TRD exhaust, BMF 20" wheels with 305/55R20" tires.
    Welcome. I am also considering the SC for my 2013 Crewmax. Good luck on the build
  21. Jun 4, 2015 at 2:16 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Welcome. It sounds like an awesome plan. By they way, since the announcement of discontinuation of the supercharger program, the inventory seems to going quickly. Get one soon if you are planning to supercharge.
  22. Jun 4, 2015 at 5:25 AM
    This is another 510 HP option. Have seen good and not so good reviews, mostly quite good: http://www.supercarsshow.com/2014/0...charged-upgrade-by-hennessey-performance.html
    The HPE500 Supercharged Upgrade Includes:
    • TVS Supercharger System
    • High Flow Air Filter
    • Fuel Injector Upgrade
    • Stainless Steel Cat-Back Exhaust
    • HPE Engine Management Calibration
    • Chassis Dyno Tuning & Road Testing
    • All Necessary Gaskets & Fluids
    • Exterior Hennessey Badging
    • "Supercharged" Door Badges
    • Serial Numbered Dash & Engine Plaques
    • Professional Installation
    • Hennessey Premium Floormats
    • 3 Year / 36,000 Mile Limited Warranty
    Whipple is the go to guy to for SCr's. Maybe he will come up with a Tundra SC sometime soon now that Toyota is done with the TRD SC (depends on demand as usual) : http://whipplesuperchargers.com/
  23. Jun 4, 2015 at 7:31 AM
    Mike Tread lightly.
    south carolina
    If you go by numbers (years) on the life cycle on powerplants the 5.7 (3uz-fe) is at end of life. Its 11 year old powerplant.
    I have a feeling this is the last year or next to last year for the 5.7. Its outdated to toyota standards by the production. I believe if toyota is watching this board they will shot me as whats in the tacoma (Subaru engine design) will end up in the tundra unless they keep using the same casting they are now with a diiferent top end.
    Tchapman1998 and Black Wolf like this.
  24. Jun 4, 2015 at 8:06 AM
    Toyota is always super tight lipped on what they are going to do to the point of ridiculousness. The 5.7L has had a good life, strong engine and all, well built, but fuel economy may be it's downfall in it's current configuration. Definitely a good sleeper truck motor, just kind of expensive to SC and tune it. Will be interesting to see if Hennessey will drop their pricing to attract more Tundra owners. Would be nice if Toyota could keep the aluminum block like you said and maybe do a redo on up. Nothing rarely leaks out of Toyota R&D. Always a guessing game.
