Gear slips when hauling uphill
Discussion in 'Towing & Hauling' started by Packer/Badger, Jun 8, 2021.
  1. Jun 8, 2021 at 7:26 AM
    Packer/Badger
    Packer/Badger [OP] New Member
    Jeff
    2017 Tundra 1794 Edition
    While in cruise control and hauling a light trailer uphill, my 2017 Tundra splits out of gear and sends the rpm's very high. After tapping the gas or break it goes back into gear. This has been happening ever since purchased new in 2017. Service station keeps telling me that nothing is wrong. No codes showing issues, etc. Anybody else experience this?
  2. Jun 8, 2021 at 7:30 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Are you sure it's not just downshifting?
    Txexplorer23 and snivilous like this.
  3. Jun 8, 2021 at 7:31 AM
    degs
    degs New Member
    2020 MGM Crewmax
    Tow in S4 in Tow/Haul mode.
    Cpl_Punishment likes this.
  4. Jun 8, 2021 at 8:20 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Does the rpm go high and you slow down? If it's actually slipping it'd rev up and you'd slow down, probably shoot to redline like if you were in neutral, and then if it re-engaged would lurch as the transmission goes from slipping to slamming power back through it. I would at a minimum change the fluid, and prepare for buying a new converter. A transmission slipping is really bad.
    15whtrd likes this.
  5. Jun 8, 2021 at 1:12 PM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    This........
  6. Jun 8, 2021 at 1:16 PM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    NEVER TOW IN OD!!!!!!!
  7. Jun 8, 2021 at 1:24 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The Cruise Control is making every effort to try to maintain Set Speed and will down shift as many gears as it's able in that effort including applying full throttle. That's why the manual recommends NOT towing and using CC. This is normal for your Tundra.
    Cpl_Punishment and 15whtrd like this.
  8. Jun 9, 2021 at 2:31 PM
    Packer/Badger
    Jeff
    I did not see that in the manual. My salesman said CC is fine. Maybe he doesn't know everything. I agree, its trying to downshift and can't find the right gear........... so, only way to stop the redlining is to shut off CC. Solved. Thanks!
  9. Jun 9, 2021 at 5:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Some salesmen know what they're talking about, some do not.
    Here are a couple tidbits:
  10. Jun 9, 2021 at 5:23 PM
    15whtrd
    15whtrd Mr. Blonde
    I will use cruise control on the flats towing. I have messed around with it a little bit, if I do hit a slight grade the truck will downshift from 5th to 4th, I will then manually put it in S4 So that it stops trying to upshift.
    My personal preference is to tow in S mode. I’m always listening for the converter to be locked up, you can tell by the RPMs. I will tow in 5tg as long as the converter is locked up, once I hear the converter unlock I know that it is creating more heat inside the transmission. At that point I will shift to 4th. When that happens, I can hear and feel, along with observing the RPMs, that the converter locks back up and I can pretty much keep it there out on the interstate. Obviously winding mountain roads are different. I prefer to be in control of the up shifting in the transmission. I actually try to beat the transmission to the punch and give it a preemptive downshift at the base of the hill. It’s all about learning what your truck is going to do. Keep that converter locked up as much as possible, and you should be fine.
  11. Jun 9, 2021 at 5:27 PM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Probably feeling torque converter locking and unlocking
