Gear Showing
Discussion in '1st Gen Tundras (2000-2006)' started by ThisOldTundra, Sep 25, 2019.
  1. Sep 25, 2019 at 4:04 PM
    ThisOldTundra
    ThisOldTundra [OP] New Member
    2000 Tundra SR5
    Just bought a 2000 Tundra SR5.... I’m going to assume this isn’t normal...
  2. Sep 25, 2019 at 4:10 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Nice flywheel you got there.
  3. Sep 25, 2019 at 4:59 PM
    BIGUGLY
    Paul
    2018 Limited
    Inspection plate is missing.
  4. Sep 25, 2019 at 5:03 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Someone forgot to put the flex plate inspection cover back onto the transmission not a big deal but why not put it back
  5. Sep 25, 2019 at 5:38 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Mine finally broke after 3-4 times having my transmission out. I’m too cheap to buy a new one.
  6. Sep 25, 2019 at 5:40 PM
    ThisOldTundra
    2000 Tundra SR5
    I found a pick and pull by me that has two 2000 tundras brought in over the past two months. I’m hoping one will have it.
  7. Nov 14, 2019 at 12:33 PM
    Professional Hand Model
    Hand Protectors
    Per this inspection cover: How does one go about inspecting the entire flex plate wheel? Put it in neutral and free spin it?
  8. Nov 14, 2019 at 12:46 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    If you have a helper have them rotate the engine by the hand using the crankshaft bolt or use a remote start button and bump the engine over while you inspect the flex plate a section at a time.
  9. Nov 14, 2019 at 12:46 PM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    To rotate flex plate to remove torque converter bolts
  10. Nov 14, 2019 at 1:26 PM
    Hand Protectors
    Sounds like danger for a hand model. I’d mess something up.
  11. Nov 14, 2019 at 1:28 PM
    Hand Protectors
    This dot looks important.
  12. Nov 14, 2019 at 1:32 PM
    15whtrd
    15whtrd Mr. Blonde
    Excuse me, your tranny is showing..
    TX-TRD1stGEN likes this.
