Gear Oil Fill Level
Discussion in '1st Gen Tundras (2000-2006)' started by zech, Apr 4, 2022.
  1. Apr 4, 2022 at 12:39 PM
    zech
    zech [OP] New Member
    2006 Maroon Tundra 4WD DC
    I'm about to change the gear oil for the first time on my '06 4WD Double Cab. I've dealt with gear oil before on motorcycles.
    When refilling after draining, I'm just filling the oil to the threads of the fill port, correct? Essentially putting in as much as you can before it starts spilling out. Right?
    artsr2002 and KNABORES like this.
  2. Apr 4, 2022 at 12:44 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep. But wait to torque the plug till after you have run it for a few days and then re-checked the level. Then, top it off and torque the plug with a new crush washer
  3. Apr 4, 2022 at 4:38 PM
    zech
  4. Apr 4, 2022 at 5:04 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  5. Apr 4, 2022 at 6:27 PM
    zech
    Roger. Will do.
    I filled it up to the threads...
    The oil I took out of the rear diff... measured about 2 quarts, of the 3.2 that I put in. Yikes... Also found 2 small flakes buried in the magnetic plug. The flakes weren't sitting on top, so must have happened a while ago. I'm gonna be staying on top of this rear diff now. Haven't done the front of transfer case yet.
  6. Apr 4, 2022 at 11:07 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Make sure you get the Allen wrench or socket good and seated in the front diff plugs so it doesn't strip out like others have had happen. Fill plug first.
    MachSlow likes this.
  7. Apr 5, 2022 at 2:29 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Fill plug first!
    Some of us have had trouble (chatter) with Mobil1 w/LSD in the rear. I now use LucasOil 80w/90 for the rear only
    Dannydirtyfingers likes this.
  8. Apr 7, 2022 at 7:06 PM
    zech
    Does anyone know the torque specs for the drain plugs? I read and set them all to 30 ft. lbs... but the front differential drain plug seemed like it should take more than that with a copper washer...
    And I don't want to crank down on that thing. I was damn afraid I was gonna strip it out trying to break it loose.
    I replaced all washers with brand new ones.
  9. Apr 7, 2022 at 7:16 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    36ftlbs rear dif, 29ftlbs front dif, 27ftlbs transfer case
    Double.O.Tundra, bmf4069 and zech[OP] like this.
  10. Apr 7, 2022 at 10:06 PM
    zech
    My rear seems fine, but my front two, not so much. The bigger line spins okay, but the thinner line doesn't move well. How do I go about replacing those two?
