Gear Oil Change Timing and Cost
Discussion in '2nd Gen Tundras (2007-2013)' started by Bloomjtundra, May 13, 2020.
  1. May 13, 2020 at 5:42 AM
    Bloomjtundra
    Bloomjtundra [OP] New Member
    Josh
    2011 Tundra DC 4x4
    I took my new to me 2011 in to Toyota for alignment after I put on my 5100 Setup. While there the service guy recommended a coolant flush. It seemed logical so I had him do it.
    the truck has 29k on it, just below the 30k gear oil maintenance recommendation in the book...so I asked about it. They quoted approximately $109 per diff, and transfer case. He then said it’s probably unnecessary unless the truck has been towing a lot or off-road, which it has done none of either from what I can tell.
    questions -
    1) what does the community think? Should I change gear oils now or let it go a while longer? I can DIY and likely would since the quoted price seems crazy high to me.
    2) what oils do you typically use? The dealer mentioned needing an additive for the LSD. My past practices on other vehicles is either Amsoil or redline product, or OEM.
    thanks for the input.
  2. May 13, 2020 at 7:13 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    1. Front/rear diff at 30k is fine, transfer case doesn’t need to be changed for quite a while longer, though it might be a good idea based on age of your truck.
    2. Toyota OEM or Redline 75w85 is what I’d recommend, any 75w90 will work as well. No 07+ Tundras come with a factory LSD (“auto LSD” is a brake based electronic system) so your dealer is pulling your leg.
    jeremyd likes this.
  3. May 13, 2020 at 7:16 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    Good to know about the LSD. So it is not a mechanical limited slip? Was that even an option? If not, it makes fluid choice easier for sure.
  4. May 13, 2020 at 7:36 AM
    ninjajay
    Spoolston, TX
    no and no, there are a few aftermarket options though
  5. May 13, 2020 at 7:40 AM
    1rooster
    1rooster New Member
    Tony
    2007 crewmax
    You are probably good for awhile but I like to be proactive . Do the rear diff your self for less than 30 bucks. C00ED875-13F7-4D50-860F-FFEB5AE61A79.jpg
    Dalandshark and jeremyd like this.
  6. May 13, 2020 at 9:09 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    thats about what I would expect to spend. If the dealer would swap them both for $100 I would have said do it but $100 each is nuts.
    Anyone have a link to a diff oil change DIY?
  7. May 13, 2020 at 9:34 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    It's a simple job. 24mm drain plug as I recall. Takes longer to refill the diff case than anything.
  8. May 13, 2020 at 10:41 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I've ran all the fancy oils and have circled back to supertech. Easy to get and meets spec. Affordable enough to swap out every couple years.
    Be ready to have a plan B if your drain/fill bolts have never been cracked open. This was my front drain. Had to use an air chisel to walk it out.
    deptrai and Bloomjtundra[OP] like this.
  9. May 13, 2020 at 9:09 PM
    TemujinNomad
    TemujinNomad New Member
  10. May 13, 2020 at 9:39 PM
    ninjajay
    Spoolston, TX
    Supertech is perfectly fine, made by Warren, they do a bunch of private labels like Kirkland (Costco), etc.
  11. May 13, 2020 at 10:40 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I used Amsoil 75w90 in the diffs and Ravenol in the transfer case. Changed both @75k miles, both diffs was their first time being changed, the magnets were covered pretty good and the oil looked pretty wrecked. Transfer case fluid was dark but not past its life span, felt good putting fresh fluid in for peace of mind. Next up is Amsoil in the trans.
    1rooster likes this.
  12. May 14, 2020 at 5:16 AM
    1rooster
    1rooster New Member
    Tony
    2007 crewmax
    Im gone try AMSOIL in my trans next. I just did a full flush 2k miles ago so it will be a while. Just make sure you drop that pan and clean the gunk and magnets first! Save yourself a lot of aggravation
    Bravohook[QUOTED] likes this.
  13. May 14, 2020 at 8:43 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Didn’t watch the video, so maybe this is redundant.
    Always make sure you can remove the fill plug first before you even consider cracking the drain.
    The vehicle must be level to get the correct amount of fluid in.
    While you have all 4 wheels off the ground, lube the u-joints on the drive shafts, as well. I use Mobil 1 synthetic, don’t cheap out. You will need to rotate the wheels to turn the driveshaft in order to get the grease fittings accessible.
    Greg
  14. May 14, 2020 at 11:14 AM
    jeman022004
    jeman022004 New Member
    Jeff
    2019 Limited CM TRD Off-road
    You get much better pricing than I do from my dealer. They wanted $185 per axle. It made doing it myself feel much better.
  15. May 14, 2020 at 11:54 AM
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    Yep watched a video from Don's Oil. Gonna follow his procedure minus the laser thermometer and lean the magnets and change the filter.
    1rooster[QUOTED] likes this.
  16. May 14, 2020 at 1:33 PM
    JLS in WA
    Good grief. You'd need to file a police report when you were done.
