Gauges with Magnuson S/C
Discussion in 'Performance and Tuning' started by BigAl, Mar 31, 2021.
  1. Mar 31, 2021 at 12:17 PM
    BigAl
    BigAl [OP] New Member
    2014 SR5 Magnuson SC
    e30cabrio and Platinum714 like this.
  2. Mar 31, 2021 at 12:29 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'm a noob, but boost is less important than afr in my opinion, I don't know if boost has actually been "useful" for me, though it can be helpful if I don't want to be pushing the truck hard (it mostly serves as a load/throttle position indicator for me more than anything). I have a digital afr/boost combined gauge from Innovate which I really like (it'll display AFR, Boost, Boost/AFR, AFR/Boost, and Peak Boost, and can be programmed to alert you of certain limits if you want), I've never had an analog afr gauge (if that's even a thing) and my gut says a digital would be better if there's a choice since you'd have a higher refresh rate than an analog. On the flip side, I've cross referenced my boost readings with an analog gauge and the opposite is true for boost, the digital gauge is taking rapid snapshots of information, so if I'm floored the boost level is constantly changing by small increments. With the analog gauge the boost reading is more "stable" since the needle cant instantly jump around. I could see this being nice for afr too I guess... Also I think (or at least on the analog boost gauge I tried) the boost line goes straight to the gauge, so you have to run a hose to the gauge itself. With the digital gauge there's just a little wire bundle that goes to the gauge, and there's a boost sensor that I mounted in the engine bay that the boost port goes to.
    Point being, digital is a lot more jittery readings that are constantly changing and analog flattens that jitter out but potentially cant react as fast and give you as detailed of information. Mine's a 2008 so different interior layout, but I made a custom bezel where the stock brake controller goes. Easy to glance at, and keeps it looking pretty factory which I wanted; might give you some ideas:
    M3Tundra-JK, V10Ace, AZTundra and 3 others like this.
  3. Apr 11, 2023 at 6:19 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I just ordered the CravenSpeed mount, does anyone have pics of their wire routing?
  4. Apr 11, 2023 at 6:21 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Cravenspeed :cool:
  5. Apr 12, 2023 at 3:25 PM
    e30cabrio
    IMG_0516.jpg Nevermind
  6. Apr 18, 2023 at 4:55 PM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    Did you have to modify the AEM AFR bezel? or do the X-series fit well?
  7. Apr 18, 2023 at 5:16 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Aem hit the wheel. Shop that installed it said they used some all thread and washers to space it back. I see the washer but not sure about the bolt/all thread. Pics if it helps
  8. Apr 18, 2023 at 5:32 PM
    50Shades
    J
    West Coast
    This helps a lot! thank you so much!
    V10Ace[QUOTED] likes this.
  9. Apr 18, 2023 at 5:35 PM
    e30cabrio
    The PSB-1 did not seem like it would fit yet did.
    I just got the Auto Meter fuel pressure gauge, it's just dropped in.
  10. Apr 18, 2023 at 5:44 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Me thinks this should be on Sniv's Speed Shop!
  11. Apr 19, 2023 at 8:04 AM
    50Shades
    J
    West Coast
    I read on cravenspeed website and there was a warning about AEM and Innovate gauges not fitting well. But that's good to know real world results could be different. I really like AEM and their auto dim feature.
    e30cabrio[QUOTED] likes this.
  12. Apr 19, 2023 at 11:09 AM
    e30cabrio
    Fuel pressure gauge is in, need to get the light wired up.
    __________________
    HulkSmurf14 likes this.
