Gauges going crazy!
Discussion in '2nd Gen Tundras (2007-2013)' started by supermotobobby, Mar 14, 2021.
  1. Mar 14, 2021 at 6:58 AM
    supermotobobby
    supermotobobby [OP] New Member
    Bobby
    2022 Tundra Platinum 4x4
    Has anyone experienced your dash lights and needles bouncing all over the place? My abs, slip, airbag, and brake lights come on intermittently and all of my gauge needles except fuel, and battery stop working. Any ideas?
  2. Mar 14, 2021 at 7:15 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I’ve never had it happen to me, but on almost all the formn’s I’ve been on and seen post’s like this, most of the time, it turns out to be a bad ground. I’m not sure about the Tudra, but I know on my 2004 Denali, it had several grounds and it doesn’t take much corrosion/oxidation at a ground to cause a problem.
  3. Aug 6, 2022 at 10:34 PM
    Heisman210
    Heisman210 Hard working guy, enjoying family
    J.M.
    San Antonio
    2010 C-Cab 6.5 SR5
    Intake, aluminum dual core radiator, led conversion, 20" Toyot wheels from 2014 limited trim.
    Following thread. I recently swapped the radiator and forgot to clamp the lower coolant hose to the thermostat. While idling in driveway checking for leaks and if it held temp the hose came loose and shot coolant all in the engine bay.
    After reconnecting, refilling, and checking again, everything seemed fine. Drove it up to gas station to fill up, no problem. On the way home traction control came on solid, the the ABS light stayed on, then my Tach, Speed, and Oil pressure gauges would dip in sequence every 30sec. The digital data above the center console would flash as well.
    It runs great, no abnormal noises of any kind. Just started the dash jitters. It seems electrical in theory, but worried it's a module of some kind. In lieu of a simple ground or sensor.
  4. Aug 22, 2022 at 1:52 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Mine has done this twice. The first time it was the ground strap between the body and transmission rusted in half. The second time it was a bad wheel speed sensor on the front driver side wheel.
  5. Aug 22, 2022 at 3:45 AM
    Adam New Member
    Time to chase the electrical gremlin.
  6. Aug 22, 2022 at 7:05 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    You have a "bug" in the communication line between all the ECUs I would bet OR potentially a bad ground.
    Data to run all these gagues and lights comes in on the same two wires, the CAN or Communication Network. If it gets a short/interference it will make all these items do crazy things as it receiving bad data at times.
  7. Aug 25, 2022 at 12:08 PM
    labola84
    labola84 New Member
    Where was the ground strap?
  8. Aug 26, 2022 at 8:12 AM
    careyrob
    Carey
    Massachusetts
    Between the right side of the transmission and the floor pan.
