Gauge Cluster Swap - 2014 to 2015
Discussion in 'General Tundra Discussion' started by HulkSmurf14, May 6, 2020.
  1. May 6, 2020 at 8:30 AM
    HulkSmurf14
    HulkSmurf14 [OP] ...Weighted Average...
    2014 Tundra Limited
    Tastefully enhanced...
    I know there are differences in the 2014 cluster and the 2015...mainly, where the ambient outdoor temperature is displayed in the lower right-hand side adjacent to the odo/trip...at least for the 2015s, that's where it is...on the 2014s, one needs to switch their display to show it as a Jitterbug phone or remote might display such information...this has "briefly" been explained to me on how to make it work, but could or does anyone have any experience in attempting such a swap? The harness connections look identical between the two, but I'm wondering if it is indeed "that easy" to just swap in a refined cluster from the 2015+ into my 2014 and I'd have the temp gauge visible without needing to sit in the backseat to read it...Any suggestions? I assume it's a "waste of money" but knowing is half the battle I suppose...
    Link to a 2014 gauge cluster: https://www.ebay.com/i/362912529750...MImaKTz8Wf6QIVAZJbCh3G2w2MEAQYAiABEgLNbfD_BwE
    Link to a 2015 gauge cluster: https://www.ebay.com/itm/2015-Toyot...25800?fits=Year:2015|Model:Tundra|Make:Toyota
  2. May 8, 2020 at 1:03 PM
    HulkSmurf14
    2014 Tundra Limited
    Haha, okay, nearly impossible or so time-intensive, it's not worth it...if I'm mistaken please educate me! Happy Friday everyone!
  3. May 8, 2020 at 3:05 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Wouldn't you have to get your odometer calibrated at the dealership if you swapped clusters so it would work?
  4. May 9, 2020 at 6:02 AM
    HulkSmurf14
    2014 Tundra Limited
    Most likely, yes...the cluster ID and mileage confirmed
  5. Jun 26, 2020 at 6:57 AM
    QuandAns42
    QuandAns42 New Member
    james
    There are likely tons of unforeseen issues with such a swap, and I definitely wouldn't consider it
    . I've worked with a shop that deals exclusively with cluster work and they're a very good resource for compatibility issues, I'd recommend you give 'em a call. https://www.instrumentclusterstore.com/Toyota_instrument_clusters.htm
