Gas tank leak
Discussion in '1st Gen Tundras (2000-2006)' started by Sampson, Oct 18, 2021.
  1. Oct 18, 2021 at 6:55 PM
    Sampson
    Sampson [OP] New Member
    2001 Tundra SR5 V8 TRD 4x4
    2001 V8 with 110k miles
    Filled the tank up a few days ago and then parked. This morning, after having sat around for a few days, it started dripping fuel out of the rear end of the fuel tank. I siphoned 3/4 of the tank and the dripping ceased. Top of the tank is completely dry.
    Considering that the leak is clearly on the bottom half somewhere (thus ruling out a broken fuel line), I think it's safe to say that my tank has a hole in it and it needs to be replaced, right? I am not interested in patching it.
  2. Oct 19, 2021 at 5:56 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd agree that a new tank is probably in order.
  3. Oct 19, 2021 at 1:17 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Maybe look into seeing if the newer 05+ plastic tank will fit?
  4. Oct 21, 2021 at 7:04 AM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    I've been told mine (2000) is on borrowed time, does anybody know if this will work?
  5. Oct 21, 2021 at 7:31 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I think you'll at least need to change fuel pumps. I remember running across a thread somewhere about it.
    Jack McCarthy likes this.
  6. Oct 30, 2021 at 7:54 PM
    lonestarduck
    lonestarduck New Member
    KG
    None
    Just wanted to show you that it can happen to a 2020 Tundra gas tank with 25K miles on it. I love my Tundra. Saved up for over a decade to buy it. But it has the most exposed gas tank I’ve ever seen. Drive 1500 miles from NC to TX. Parked it for a couple days with less than 1/4 tank. Then went to filling up and it had a massive hole in it,..you see. Had to call the local fire department because my $90 worth of gas was pooling next to a sidewalk and under other vehicles. After three day battle with insurance co., finally got them to reimburse me for a $2400 (dealership) replacement of the tank. I’m unaware of hitting anything on the highway. I do have a farm I drive around on, and I could have hit something there prior to the long road trip. Again, I love my Tundra, but I had a Chevy truck I drive for 200K rough on-road and off-road miles. I hit tins of limbs and other stuff. This never happened. The exposure of the tank, with no factory skid plate to protect it, really surprises me. Thinking about getting after-market plates to protect the gas tank. Anybody ever done this with their Tundra? Thanks. I’m new to this forum. And I’m not a forum kinda guy, so please pardon my long-winded post here.
  7. Oct 31, 2021 at 4:09 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    That looks a lot like you caught someone in the middle of stealing gas and not a random puncture.
  8. Oct 31, 2021 at 9:08 PM
    Sampson
    Good as new.
    None of the videos mention the rusted out metal clamp that holds the ABS wiring in position against the rear of the gas tank. That was annoying. Otherwise it went pretty smooth.
    w666, bmf4069, FirstGenVol and 7 others like this.
  9. Nov 1, 2021 at 1:51 PM
    Cam here to say this. This is exactly what it sounds like to me. Classic meth-head-tweaker/crackie tactic right here. Put the hole high enough that it dumps right into your can, but not high enough you leave the owner stranded. Just high enough they can drive far enough away they won't be near where you did the deed when they realize what happened. Had a tweaker living behind me when I had to relocate to the city for work a long time ago. Thankful I had a garage, he did this shit all over the neighborhood for years. Like magic, it suddenly stopped when he set his house on fire running gas powered generators in the attic because he couldn't afford electricity.
    Did you know in many major cities you can run gas powered generators all day long, legally? Yeah. Neither did I, nor my neighbors. That drone ... ugh.
    Hope you proactively replaced the fuel pump while in there ...
    I won't make that mistake again. If that tank is coming down for anything, I'm changing the fuel pump.
    Congrats either way!
  10. Nov 1, 2021 at 1:55 PM
    Sampson
    Truck only has 110k miles on it. The pump and the inside of the tank looked brand new. I've had no fueling issues, and honestly, the tank was not that difficult to drop. So no I did not replace the fuel pump.
  11. Nov 1, 2021 at 2:01 PM
    I mean, I hear you, I've just had it happen more than once. Last time was on a '98 that had 64k miles on it. Age kills things just as easily as miles.
    But if you find dropping the tank easy, I'm not one to criticize. Was just reminiscing about the last time it happened to me.
  12. Nov 1, 2021 at 2:11 PM
    Sampson
    Normally I am a big proponent of replacing things ahead of time, especially if the cost isn't too high, but I just don't see it being necessary in this case. If a fuel pump fails after 64k miles, I wouldn't blame the pump, or its age. I'd be more inclined to believe that the previous owner was the type of person to drive around on empty all the time, only ever putting in $10-$20 at a time. Fuel pump probably spent most of its life overheating as a result of not being submerged in fuel.
    shifty`[QUOTED] likes this.
  13. Aug 6, 2022 at 7:24 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I'm getting ready to replace my fuel tank. I noticed that your new tank appears to be from Rockauto. I have a 2004 AC, the owner's manual lists fuel capacity as 26.4 gallons. All the direct replacement tanks at Rockauto (et al) show that they are 18.4 gallons. That makes no sense. @Sampson can you share the p/n you used, and your experience as to its capacity?
  14. Aug 6, 2022 at 7:46 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    So what exactly caused the leak? Was it corrosion or something else?
  15. Aug 6, 2022 at 9:01 AM
    w666
    Maryland
    Don't know yet. After I replaced the rusty straps, it started leaking just a couple of drops a day. Before I drop the tank to check it out I'm just trying to cover the bases. A new OEM tank is ~ $850! The Dorman is ~ $300, but it apparently only holds 18.4 gal !? I think I found a Denso fuel pump (if I'm dropping the tank, it would be silly not to change it). Maybe I'll be able to have the tank repaired if it's not too bad.
    I wish I could figure out how to hold the tank in place with the straps off so I can drop the plastic bottom cover and see what's going on.
  16. Aug 6, 2022 at 9:16 AM
    Jack McCarthy
    Bill
    North of Boston
    Can’t take an impact to the bed t55 bolts and access from the topside?
  17. Aug 6, 2022 at 9:18 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    Looks like someone drilled your tank to steal gas.
  18. Aug 6, 2022 at 9:27 AM
    w666
    Maryland
    I hijacked this thread because I wanted to learn about OPs replacement part. The picture of the tank with gas pouring out is yet again another guy's (2020 Tundra) tank. I'll bump my original thread and get of this one...
  19. Aug 7, 2022 at 9:13 AM
    Sampson
    The 18.4 gallon specification is incorrect. What you're looking at in my photos is supposedly, according to Rockauto, an 18.4 gallon tank... and yet it is exactly the same shape and size as the tank I removed. The website is wrong.
    Jack McCarthy and w666[QUOTED] like this.
  20. Aug 7, 2022 at 9:15 AM
    Sampson
    In my case, yes, corrosion. Truck lives in Northwestern Ontario, Canada. Basically worst case scenario in terms of road salt.
  21. Aug 7, 2022 at 11:12 AM
    w666
    Maryland
    Excellent...thanks!
    Oh...and which one? Dorman, or another?
  22. Aug 7, 2022 at 1:34 PM
    Jack McCarthy
    Bill
    North of Boston
    I'll have to check that on mine since I've occasionally gotten a leak and couldn't tell where it was leaking. Mine only occurs when I fill the tank though.
