Gas tank falls out
Discussion in 'General Tundra Discussion' started by larry2007, Dec 19, 2018.
  1. Dec 19, 2018 at 2:52 PM
    larry2007
    larry2007 [OP] New Member
    Larry
    2007 Tundra
    Has anyone else had this experience: Got the recall notice for frame rust for my 2007 Tundra. Dealer said rust wasn't bad enough to require replacement. Three weeks later the gas tank fell out on the road. Repair shop said the frame part that holds the tank straps rusted through. Is this common? This Tundra only has 65,000 miles. I regularly had it washed in the winter including underbody spray. I've been waiting two weeks for the new frame part to arrive. Very disappointing.
  2. Dec 19, 2018 at 3:02 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    You need to treat the underside with an oily product every year. Known, motor oil, transmission fluid, fluid film are examples
  3. Dec 19, 2018 at 3:09 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Id take it back to the dealer that said it wasnt rusty enough for a new frame.
  4. Dec 19, 2018 at 3:14 PM
    This ^^^^
  5. Dec 19, 2018 at 3:55 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Stealerships have a deal with Toyota and don't make their standard hourly rate for fixing recalls. I suspect you were turned away simply because it s wasn't profitable enough the dealer. Replacement shouldn't be a question now that the gas tank has your point for you.
    15whtrd likes this.
  6. Dec 19, 2018 at 4:09 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    the rust recall is literally to prevent that. They should take care of it or this is lawsuit material.
    NewImprovedRon and 15whtrd like this.
  7. Dec 19, 2018 at 4:09 PM
    FXFormat
    FXFormat New Member
    Damn everyone with NE trucks need to inspect their straps now, gas tank falling out sounds awful, could cause a huge fire/explosion
    NewImprovedRon likes this.
  8. Jan 19, 2020 at 4:40 PM
    Eyball
    Eyball New Member
    2008 CM Limited 4 x4 5.7
    I know this is kind of old but to the original poster what did you end up doing? I have the same issue with my 2008. They did the frame coating 2 years ago and most of it is flaking off now. The rear Gas tank mount is hanging on by a thread.
  9. Sep 1, 2020 at 1:11 PM
    BadBrad
    BadBrad New Member
    Robert
    2008 Tundra
    Old Thread but yeah same thing happened to me except I just bought the truck from a Dealer one town over. (for 14K) Beautiful looking and running truck, smooth not a rattle in it, not a drop of fluid leaking and motor smooth as a sewing machine with only 84 K on it. I put less than 300 miles on it from purchase and hear rubbing scraping noise. The rear gas tank strap mounting point had rusted off on the driver side and had swung down and was rubbing on the driveshaft. The rear of the gas tank had dropped about 12 inch's. The only thing holding it up was front strap and filler neck. If I had had a full tank of gas when it happened it well may have hit the deck.
    I strapped it up with a ratchet strap and took it into the local Toyota dealer. They looked at it and said they cannot replace just the rusted out crossmember they have to replace the whole frame even though the crossmember is available as a replacement part (liability??). Told me the truck had been in for corrosion prevention recall in OCT 2019 (at a different dealer) and had some frame plugs put in and inside of the front frame rails sprayed with anti corrosion material.
    Price quoted to fix was $3637 .92 for frame, replacement rear springs and Hardware $2138.92 (optional but suggest it be done at this time). a couple hundred for fluids and miscl. bolts
    Total Parts: $6673.94 and then 70 hrs shop time for another $7700.00 in labour.
    Grand Total about $14,373.94
    **If I opted to not replace rear springs Grand Total of: $12,235.02
    They said my vehicle had passed the 12 yr. extended warranty on March 02, 2020.(12 yrs since date first put into service per terms of class action lawsuit) So they said there was nothing they could do to help me out, but I could call Toyota Corporate to see if they would do anything...long story short they basically said tough shit we are not going to do anything but thanks for reporting your concerns...
    So a body shop guy I know gave me a referral to a shop nearby and said he might be able to help me out. Took it in, he looked it over and said Toyota dealer saying a new frame was necessary was BS the main rails were good and solid and so were the other crossmembers. (The undercarriage really doesn't look that bad, 70% of it is still firmly encapsulated by some kind of coating and the main frame pieces are not anywhere near rusted through so not sure why Toyota said it couldn't be replaced...only thing I can think of is liability concerns) He said it looked like about a 10 hour job to pull the bed, gastank, and lift up the cab a couple of inch's for clearance, cut out the rivets, pull the old crossmember and put in a new crossmember secured with class 8 hardware.
    I found the crossmember online and ordered it for $357.00 delivered to my door.
    His labour charge right at $700.00.
    Total $1057.00
    I'll clean up the rust on the frame, hit it with some Ospho, sp ray it with encapsulating paint and then a oil coating. If I can hold the rust at bay and get five or six years out of it I won't feel like I got F@#Ked to badly.
    End of my sad tale!
    Leo's first likes this.
  10. Sep 17, 2020 at 5:18 PM
    DH07TUNDRA
    DH07TUNDRA New Member
    2007 Limited 4WD Tundra
    3.5" Suspension lift
    That's crazy. Did he say how difficult it was to cut/pop the crossmember rivets out? I'm about to do the same and fabricate a spare tire crossmember, since can't seem to find one anywhere. Did you replace with an OEM or aftermarket/frame repair crossmember? Where did you find it? Appreciate the story...seems that many of us are in the same boat...at least poring money in this feels like I own a boat.
    Thx,
  11. Aug 1, 2023 at 8:24 AM
    JimFromNJ
    JimFromNJ New Member
    2008 Tundra
    Own a 2008 Tundra. Bought used from neighbor who was original owner. Was great until a few years ago. Have had to replace AC evaporator, significant brake work, dealer blew me off on frame rust recall, and now the rear gas tank strap has rusted through as you all describe above. Love the Tundra concept, but what a piece of crap to own! Also own Honda and Acura vehicles. Even a Honda outboard. No where near the corrosion issues as this Toyota. No more Toyotas for me!
  12. Aug 1, 2023 at 8:37 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    It's a Land Yacht
  13. Aug 1, 2023 at 9:27 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    15yo vehicle in the rust belt? most are probably in the crusher years ago. It is not just toyota.
    EmergencyMaximum and Terndrerrr like this.
  14. Aug 2, 2023 at 6:02 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    My 2007 has zero frame rust and both gas tank straps rusted through 2 yrs ago or so. Pretty easy diy fix under $100.
  15. Aug 2, 2023 at 8:08 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    If your truck's fuel tank strap rusted through a few years ago, either you or your neighbor (both probably) were completely negligent in taking care of the truck. Someone ignored salt corrosion for 12 years while living in New Jersey of all places, someone also didn't inspect underneath the truck when they bought it, and now you want to call the truck a piece of crap. Lololol.
    2mchfun and 831Tun like this.
  16. Aug 2, 2023 at 8:12 AM
    Kung
    KG, VA
    And it's 1 of 1 post. LOL
  17. Aug 2, 2023 at 8:18 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    It's like someone searched for something on Google, clicked the first result, registered, and will probably never come back ever again!
  18. Aug 2, 2023 at 11:37 AM
    Leo's first
    Groton ma
    Oh yah he gone :wave:
  19. Aug 2, 2023 at 11:43 AM
    MedCityMoto
    Went and bought a F150 instead - can't run out of gas if it don't run!
    Or would a Ram make more sense, gas tank won't fall off if it's always empty?
