Gas smell after running.
Discussion in '1st Gen Tundras (2000-2006)' started by Cbb129, Feb 25, 2018.
  1. Feb 25, 2018 at 2:14 PM
    Cbb129
    Cbb129 [OP] New Member
    2002 Blue Tundra SR5
    After I drive my 2002 Tundra for a bit, when I get out there is a gas smell. Looked around underneath and can't see any leakage from the tank anywhere. Any ideas ?
  2. Feb 25, 2018 at 2:30 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I had that on my 05 and it ended up being a dry rotted filler tube.
    Black Wolf likes this.
  3. Feb 25, 2018 at 2:34 PM
    Cbb129
    Is it an easy do it yourself fix, or is it involved and need a shop to do it ?
  4. Feb 25, 2018 at 2:50 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not real hard, there's just enough room to get it done without removing anything else. Took about a half hour in the driveway.
  5. Feb 25, 2018 at 3:09 PM
    Cbb129
    Do you have part # or exact name of it by any chance ?
  6. Feb 25, 2018 at 3:32 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    77213-0C030 Fuel Tank Filler that number only lists for 03-04 though.
  7. Feb 26, 2018 at 7:17 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    15whtrd likes this.
  8. Mar 17, 2018 at 8:02 AM
    Cbb129
    Wound up being a leaking gasket on fuel sending unit.
    NewImprovedRon and nk1794 like this.
  9. Apr 29, 2018 at 3:10 PM
    Professional Hand Model
    Hand Protectors
    Yeah. Had a similar issue (smelling gas vapor) with a gas tank vapor tube that dry rotted at the connection. The rubber tube was in good condition except right where it slipped onto the male fitting. Cut the rotted end part off with a razor and reconnected. Fortunate there was extra slack in the hose.
    While in that area went ahead and zip tied all the adjacent hoses together as the original clips/mounts were loosened from age. Tighten and resupported everything.
    NewImprovedRon likes this.
