Gas pedal acting strange.
Discussion in '1st Gen Tundras (2000-2006)' started by Timeout, Mar 28, 2021.
  1. Mar 28, 2021 at 4:35 AM
    Timeout
    Timeout [OP] New Member
    Helping a friend resurrect his 2000 Tundra V8. Build date is 08/99. Problem with gas pedal response. Half way nothing and then 3000 rpm. I have cleaned throttle body. Yes there was a check engine light. Couldn't read codes because of no power to OBDII. Fuse is good. Story is that this all started after hitting a deer. Any suggestions?
  2. Mar 28, 2021 at 4:56 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    First Welcome !
    Don't hit deers :facepalm:
    When hitting the deer, did he happen to lock up breaks, causing pistons to seize ?
    Sure would help if codes could be read !
    Jack it up and check that tires can spin freely in neutral ?
  3. Mar 28, 2021 at 6:21 AM
    Throttle position sensor? Had a Jeep that would misbehave this way after some mud runs.
