Gas brands and mpg
Discussion in '3rd Gen Tundras (2022+)' started by CarlosV, Apr 1, 2022.
  1. Apr 1, 2022 at 7:34 AM
    CarlosV
    CarlosV [OP] New Member
    Armando
    2022 sr5 4x4 celestial gray
    Does the brand on gas affects mpg?
  2. Apr 1, 2022 at 7:40 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Not in my experience. I've only had 1 bad gas experience, it was at a completely No Name Yellow building gas station, never again - who knows where they got that watered down stuff.
  3. Apr 1, 2022 at 8:10 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    No. Pretty much all brands of gas are refined at the same refineries locally. The only difference is the additives/detergents/cleaners that the brands add, which happens right before the tanker truck leaves the refinery. At a Chevron refinery I have worked at, there were stations for several brands that trucks would pull into for the additives.
  4. Apr 1, 2022 at 8:25 AM
    CarlosV
    Armando
    I noticed when I have the Tacoma filled with chevron Exxon or shell lasted longer compare to Valero or Costco, just me and my experience
  5. Apr 1, 2022 at 11:10 AM
    Breathing Borla
    Northern Illinois
    Im kinda in a related industry, we remove the tanks and tank systems and clean up the mess.
    what I can tell you is go with top-tier fuel and what's really important is the maintenance of the local station, there are fuel filters, water monitors in the tanks, vapor recovery systems, etc that will allow more containments in if not well kept up. Some of these shithole stations where the pump is slow is not only because the pump is warn out, fuel filter clogged, etc.
  6. Apr 2, 2022 at 8:43 PM
    mass-hole
    mass-hole New Member
    I will say that these engines(3.5L turbo direct injection) are more sensitive to fuel than a port injected V8, but in general they should run fine on most any brand.
    that said, I have filled my Ecoboost at Maverick a couple times and it really does suck. Every time I ran Maverick my MPG’s tanked. I have also had a bad tank at Sinclair once or twice. I try to stick to Exxon, Chevron, Shell and, if I have to, P66.
    Pac12AfterDark likes this.
