Garmin Powerswitch - Fogs
Discussion in '3rd Gen Tundras (2022+)' started by sulli155, Feb 14, 2024.
  1. Feb 14, 2024 at 4:51 PM
    sulli155
    sulli155 [OP] New Member
    Ryan
    I'm swapping out my fog lights with some BajaDesigns lights that I'll hook up to a Garmin Powerswitch. As an option, I wanted to hook up a control input on the garmin to be run off the factory harness for the fogs. So factory fogs on = garmin triggered.
    Should that be possible? I've hooked things up properly (I thought) but it doesn't seem to trigger. The setup is from old fog light harness (not fuse) to Garmin control input.
    TBH, I haven't given it a ton of troubleshooting, but before I did I wanted to poll all of you experts.
    Thanks team!
  2. Feb 14, 2024 at 5:19 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Have you checked to see if the fog OEM switch is a negative switch instead of positive? The Garmin looks to be a positive switch only.
