Garage interior
Discussion in 'Home Improvement' started by Grizzly660, Aug 19, 2018.
  1. Aug 19, 2018 at 7:36 PM
    Grizzly660
    Grizzly660 [OP] 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    We bought a house and had a 30x32 Morton building garage built. I've been slowly working on it inside. I've done studs, rafters, r19 rolled insulation and just finished the poly wrap.
    Now is where I'm stuck on what to finish the inside with and wondering what everyone else has done? I want least amount of $$$ as possible.
    Once I decide on a covering, I can do the ceiling and blow in insulation. I like the rustic type look which there is an old hay bale barn by a local farm that is about to fall over covered in old corrugated steel I'm sure I could get for little to nothing but a lot more work/time and just do the ceiling and maybe wainscot...
    ColoradoTJ, Mountun Goat and Sas like this.
  2. Aug 19, 2018 at 7:52 PM
    Grizzly660
    North Dakota
    Inside/outside
  3. Aug 19, 2018 at 7:54 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Sorry, I’m no help. Just wanted to say I wish I had that big of a garage!
  4. Aug 19, 2018 at 8:11 PM
    Aron9000
    Aron9000 New Member
    Aaron
    Get that corrugated steel for free or almost free, that would be my choice. Yeah it might be a PITA to install, but you can't beat free or close to it.
    I'd also look at wood paneling of some sort. You know that tacky crap in your mom's basement, yeah that stuff would be awesome for a garage. There are a few different types, some of it is actual real wood boards, most of the wood board stuff is pine of some sort with a stain. Will take a good bit of time to install the real wood boards.
    The other type is cheapo manufactured sheets, some of it looks better than others. Basically its plywood with synthetic woograin. Very easy to put up, its like hanging drywall but you don't need tape/mud the seams.
    I've also seen that wainscoting stuff, looks like real wood, you can paint or stain it, but it is basically a manufactured plywood product. You can put that up, just leave it unstained, gives you that real wood look(will be fairly plain light pine sort of finish) without the hassle of installing individual boards.
    Of course the latest thing is to use reclaimed wood, aka barn wood. That would look really cool, but can be pricey if you buy it from somebody. If you know somebody who has an old barn they are tearing down, ask about the wood. That stuff is really hot right now.
  5. Aug 19, 2018 at 8:26 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Maybe put up some slatwall?.
  6. Aug 19, 2018 at 8:26 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Great garage space you’ve got there! I would look into T1-11 plywood sheets. They come in different thicknesses. Most common thickness is 1/2” and 3/4” thick. Personally I would do the 3/4” plywood but if cost is your main focus then 1/2”. You can also just do green board Sheetrock and just tape and float it.
    NewImprovedRon likes this.
  7. Aug 19, 2018 at 9:19 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm a fan of sheetrock, easy to hang and easy to repair when you decide you want another outlet, plumbing etc... I'd run 1/2" pvc in the attic area for compressed air and have several convenient drops.;)
    bmf4069 likes this.
  8. Aug 19, 2018 at 11:01 PM
    koditten
    Kirk
    Midland of the Mitten
    I used plain old OSB. I even put the stamped dates facing in so I could reember what year I built my shop.
    My walls are 10' except where the vaulted ceiling section is. I used barn tin ( the same stuff that is on the outside of your barn) for the last 2'.
    I wanted to use OSB so I could hang shelves or cabinets anywhere. No fusking around trying to find a stud.
    C9F_rE1qebvR3IbTB84_8dogzlRiJSOga72gbA8B_2646a1d5791ab8458aa5da09c54afcbd026e0dc3.jpg
    My shop is a mess. Don't judge me.hPjqlAccsDgJrZeddFY2IhxKxSfqQ_yfOIV6GD1P_714aaa8c6736e6ffb7f51ed8109006a19353374d.jpg
    aperezsh, Sas, JC303 and 5 others like this.
  9. Aug 20, 2018 at 3:48 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I did white liner in my 40x45 panel. Sucks to put up but is easy to clean and super reflective.
  10. Aug 20, 2018 at 3:52 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    I used sheet rock on my sides and paid less than $100 to complete my oversized two car garage.
    Went to Lowe’s and selected the ones damaged at the corners. Clerk sold them for 1/2 the cost.
    Wheel and deal em!
    SouthBoundSteve and koditten like this.
  11. Aug 20, 2018 at 4:15 AM
    War Machine
    War Machine SSEM # 5 3MW
    I’d love to have that kind of space in my garage. Only one of my four vehicles will actually fit in my “3 car garage”.
    koditten likes this.
  12. Aug 20, 2018 at 5:19 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    :bowdown: that's garage is amazing!
    I have nothing to bring to the table, my apologies.
    TheBeast and NewImprovedRon like this.
  13. Sep 7, 2018 at 12:07 PM
    Sid Vicious
    Sid Vicious New Member
    N. GA
    2017 Tundra CrewMax
    7D979DB4-1C75-43B9-90EA-50705C487876.jpg Slowly getting my garage into shape. Finished tiling it and installing overhead storage. Still working on getting it cleaned out so my wife can resume parking inside.98F288B9-301A-4145-BF64-CE0866FD3147.jpg
    Sas and GNTundra like this.
  14. Sep 7, 2018 at 1:42 PM
    My is stick built but I sheetrocked the walls and channel drain metal on the ceiling makes for great reflection of the light. This isn't a good picture but you can get the idea.IMG_20180723_182647195.jpg IMG_20180414_114926001.jpg
    aperezsh, Grizzly660[OP] and Sas like this.
  15. Sep 7, 2018 at 2:37 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I like it. Wish i had that space. I would first pipe to outlet/data boxes to the ceiling around the room. The I would osb and drywall. The wood behind drywall makes it easier when you want to mount stuff. Wonemt need to search for studs.
  16. Sep 7, 2018 at 6:17 PM
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    I'm going to do plywood in the end where my shop and bench are so I can hand cabinets and then white steel liner everywhere else. The good/bad of steel is another row of either purlins to screw to. Good is I have 8 1/2" of fiberglass in the walls, bad is the loss of the space. I framed my exterior walls 2x6, 16 OC.fullsizeoutput_8aa.jpg IMG_1216.jpg
  17. Sep 7, 2018 at 7:52 PM
    Aron9000
    Aron9000 New Member
    Aaron
    Suprised to see the Toyota in there with that GM garbage, figured you'd have a late model Chevy truck. JK, love the last of the Trans Am's and that 80's Chevy truck looks like you've put a lot of love into it, its pretty bitching.
  18. Sep 7, 2018 at 7:58 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    How do you get corrugated steel for free? I need some for my pergola?
  19. Sep 7, 2018 at 8:09 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Wouldn't that corrugated steel echo like crazy? That'd drive me insane!
  20. Sep 7, 2018 at 8:09 PM
    Thank you Sir! I was once a GM only guy but found the Tundra and won't look back. Lol
    But these two are not going anywhere.
  21. Sep 7, 2018 at 8:40 PM
    Aron9000
    Aron9000 New Member
    Aaron
    I used to daily a 1999 Camaro Z28/automatic. Really fun car, stupid fast for 2003(hell low 13's today is still fast IMO). Loved the look and that ass on the ground seating position, felt like you were driving a poor man's Jaguar XJ220 lol. Sold it, missed it, bought another one in 2010, a 1998 Camaro Z28, rag top, six speed. That was more of a garage queen, got it for a steal at $8,000 with 92k one owner miles, it was immaculately clean even with the miles on it. Had it for 2 years, put 7000 miles on it, moved, didn't have space for it, wanted a newer daily driver, sold it for $10k. Fun cars, loved the LS1 and styling, and hell both mine were very reliable as well(except for that weak ass rebuild it at 100k miles 4L60e automatic).
    If I ever have unlimited garage space, I'd buy an 80's Silverado like my grandpa had, two tone black/grey, 1/2 ton, reg cab/short box. Man that was kind of his retirement gift to himself, he kept that truck looking immaculate, had a set of craigers and white letter tires on it.
  22. Sep 8, 2018 at 9:23 AM
    Outbound
    Aaron
    Northern Alberta
    Nicest garages I've been in have OSB covered with sheet rock. Gives you the clean look but also allows you to mount anything you want wherever you want.
  23. Sep 8, 2018 at 9:35 AM
    Capt J-Rod
    Ohio
    The problem now is the cost... Plywood is through the roof! $28/sheet for 1/2 good one side. Steel is actually cheaper. I don't want to finish all the drywall. Steel is done as soon as it is screwed on & easy to clean.
    NewImprovedRon and Sas like this.
