Fuses
Discussion in '2.5 Gen Tundras (2014-2021)' started by Louielion, May 29, 2021.
  1. May 29, 2021 at 8:43 PM
    Louielion
    Louielion [OP] New Member
    2015 1794 e 4x4
    Anyone knows where is the turn signal fuse?
  2. May 29, 2021 at 8:50 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    #16, 15 amp. Under the hood.
    TTund16 likes this.
  3. May 30, 2021 at 9:52 AM
    Louielion
    2015 1794 e 4x4
    thank you!! i did check it out and is not bad, it says that controls the hazard lights witch works except the turn signals,
  4. May 30, 2021 at 10:03 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Turn signals are controlled through the ecu. If none are working, you may have a bad stalk.
    Louielion[OP] likes this.
  5. May 30, 2021 at 12:20 PM
    Louielion
    2015 1794 e 4x4
    Got the lock security light flashing, any one knows how to desarm it?20210530_121607.jpg
  6. May 30, 2021 at 1:47 PM
    Louielion
    2015 1794 e 4x4
    Thanks!!
